Old 06-27-2013, 07:22 PM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
The Holy Grail of the ACs
Eventually we will need to replace the 2 AC units on the Avion and we will like to know if there is a Holy Grail of the ACs (super cooling capacity, able to keep it cool in Arizona summer time, power saver and quiet)
So if you can please share your experience with the 15K BTUs will be great.
thanks for your input!
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 06-27-2013, 07:44 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
There are currently 6 different units available form 4 manufacturers:
DOMETIC Penguin II low profile in high capacity (15K)
Brisk Air 15K higher profile
RVP COLEMAN Mach 8 super low profile 15K
Mach 3 higher profile 15K
• Advent (CHINESE) 15K high profile
• Atwood (new to market) 15K high profile
My opinions:
Dometic has the best extended warranty of all available units 2 year factory plus optional 2 + 1 year additional warranty. This means a factory replacement of a bad unit for 4 years parts and labor, plus parts only in the 5th year for around $100....servicable thru ANY authorized Dometic service center.
RVP has a 2 year factory warranty with available extended 3 year additional. From my experience with RVP, they typically want the defective unit FIXED rather than REPLACED after the initial 2 year warranty and most RV Techs and service centers are not capable of changing compressors, adding process valves, finding and fixing leaks or re-charging systems. Regular residential A/C techs want nothing to do with RV units!
Advent has a 2 year warranty and will replace bad units. I have only seen a couple of these, and I'm not impressed with the design, construction or warranty. They are new to the RV air conditioning world and have a very long way to go!
Atwood has been in the furnace and water heater business for quite a while. They have recently entered the RV refrigeration scene with ammonia/helium gas/absorption units. Haven't seen any of these in new trailers or MoHOs yet so I can't comment. They also recently entered the RV air conditioning market. Haven't seen any of their units yet, but they claim to get the equivalent of 18K of cooling from a 15K unbid
If it is anything like their smoke and mirrors EXT series of water heaters, you can have them!
As far as reliability, Dometic and RVP have my vote....about equally. I will say that I replace a lot more Dometic units, but that is because they have the commanding presence in the RV field. I have also noticed a move by the very high end motor home manufacturers to go with the new RVP Coleman units over the Dometic versions.
Which is best? Toss-up! Ford, Chevy or Dodge..........
Questions?
Old 06-27-2013, 08:10 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A friend in the commercial end of refrigeration business -- and an RV'er -- thought the RVP COLEMAN choice slightly better. I installed the 15k unit on my interim 32' Silver Streak turned it on and ran it the next nine months almost non-stop.
Ugly, though. Why the newer 1990 TT will have their new low profile 15k unit. IMO the rise above the roof is worth consideration, even on your aero 5'er.
Old 06-27-2013, 08:17 PM   #4
reinergirl's Avatar
Hollis , New Hampshire
The holy grail? What about Sergei's (smokeless joe) LG “Art Cool” split system air conditioner?
His thread
http://www.airforums.com/forums/f227...tml#post967026
reinergirl is offline   Reply With Quote
Old 06-27-2013, 08:39 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A 5'er the size of his will need good air distribution . . the downfall of the split system. OTOH there are commercial / bus systems that can go in a big storage compartment. $$$$
Old 07-03-2013, 12:41 PM   #6
drifter45's Avatar
1988 32' Excella
Church Point , Louisiana
My opinions:
Questions?
Lew will the Dometic Air Conditioner Drain Kit you spoke about work with any of the unit you mentioned? Thanks in advance.
drifter45 is offline   Reply With Quote
Old 07-03-2013, 03:15 PM   #7
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
Why on earth Coleman went with that God-awful horrendous squared off giant depressingly horrific hideous exterior unshapely extremely hellishly disgustingly ugly exterior shroud I'll NEVER know. I would NEVER put something so ugly on ANYTHING.
ESPECIALLY when the OLD style shrouds looked GREAT!!!!
ggoat!!! is offline   Reply With Quote
Old 07-03-2013, 03:35 PM   #8
lewster's Avatar
Drifter,
YES!
I recently added the Dometic drain kits to a couple of RVP Mach 15 (15K not low profile heat pumps) and they worked well. You have to do a bit of tubing surgery, as these units have drain holes at a different width than Dometic, but they work just the same!
The Mach 8 can be had with an integrated condensate pump which takes the place of the drain kits.
Old 07-03-2013, 04:13 PM   #9
Olie's Avatar
2004 30' Classic
Beaumont , Texas
Lewster,
I called Dometic, asked what the btu rating is for the high capacity Penguin II HP. They would only say that it was High Capacity and would not provide a btu rating. My assumption is that it must be something between 13.5K and 15K. However , I see where you and others refer to it as 15K.
What is your take on Dometics comment?
Olie is offline   Reply With Quote
Old 07-03-2013, 04:24 PM   #10
OldVwHunters's Avatar
1969 18' Caravel
Northwest , Missouri
Images: 35
LOL!! Think you could tell us how you really feel about the looks of it?
OldVwHunters is online now   Reply With Quote
Old 07-04-2013, 11:53 AM   #11
drifter45's Avatar
1988 32' Excella
Great. Thanks for the inf.
Old 07-04-2013, 12:46 PM   #12
lewster's Avatar
Originally Posted by Olie View Post
Lewster,
From the feed back I have gotten from my clients that have upgraded their Dometic units from 13.5 to the 'high performance', they have been universally satisfied with the cooling capacity of the new, larger units.
From what I have seen, I would suspect that they are even a little larger in capacity than 15K, but when I spoke to a resource I have at Dometic, he was equally non-committal about the exact size, saying only that it is 'similar' to the old 15K units but that they didn't want to get into a 'capacity race' with their competition.
Old 07-11-2013, 06:51 AM   #13
Rye , New Hampshire
Split zone AC
His thread
Reinegirl,
I too have been intrigued with Sergi's AC adaptations. I have been toying with the idea of replacing that gawd Awful roof top rattler ( in a 22' 2013 sport) with this unit KSIN009-H119 9000 BTU Mini Ductless Split AC - Heat Pump
They are so quiet and efficient especially with the inverter system.
I have an email out to him asking for advice. Will post later.
Zeke
zekeobond is offline   Reply With Quote
Old 07-11-2013, 07:35 AM   #14
lewster's Avatar
Originally Posted by zekeobond View Post
Reinegirl,
Zeke
How long do you intend to run an A/C unit from an inverter? How large is your battery bank? You might be sorely disappointed when you add in the Peukert effect and realize that your initial calculations do not account for this.
