Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 08-01-2009, 02:39 PM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Testing an Armstrong AC for signs of life
All--
I recieved a few comments that I should keep the mighty Armstrong Sea Breeze unit. So I'm doing a rough check of the system.
When I trun on the switch to any of the settings, the fan spins right up and blow a lot of air, but the compress does not turn on. After looking at the wiring schematic cleverly pasted on the interior of the AC, it looks like I should get 24 VAC across the open thermostat with the unit on. Right now I get zero volts across the thermostat
Does anyone know where the 24 VAC transformer is on the AC?
Ron
ronstory is offline   Reply With Quote
Old 08-01-2009, 05:01 PM   #2
kokopat's Avatar
Hendersonville, NC , North Carolina
Transformer location
I took this the other day of mine from our 1968 overlander.
kokopat is offline   Reply With Quote
Old 08-01-2009, 05:47 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I'm pretty sure that the transformer was located inside a metal box that was around 10"x3"x5'. You would have to remove the inside cover to the unit. It would be located on the curbside around the middle of the unit. It had a large romex cable running into the box as well as all the wires from the remote thermostat.
Richard
azflycaster is online now   Reply With Quote
Old 08-01-2009, 11:23 PM   #4
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Kokopat and Richard--
thanks for the pointer I'll go digging tomorrow and see if the transformer has 24V at the terminals. I'm going to be actually be a bit annoyed if the Armstrong works because I've been eyeing a new one for a while now.
Ron
Old 08-01-2009, 11:26 PM   #5
ronstory's Avatar
1975 23' Safari
Portland , Oregon
BTW, Kopopat... welcome to the forum. You be working your way to rivet master soon.
Ron
Cool Signs silver&gold Fun & Games 16 05-16-2009 12:48 PM
Stupid Signs! rickandsandi Fun & Games 74 02-17-2009 04:58 AM
Road signs azflycaster Off Topic Forum 25 05-03-2006 10:00 PM
Signs of Spring DEO Off Topic Forum 7 04-20-2006 09:19 AM
Warning Signs! Silvertwinky On The Road... 10 06-24-2003 01:41 PM
