Old 02-17-2006, 12:14 PM   #1
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Term'x catalytic heater
I have a Therm'x catalytic heater in my trailer and the mounting screws to the wall have become loose. I removed the front grill and the lower plate, but I need to remove the pad to get to the mounding screws. I have searched everywhere for information regarding this, but have found nothing helpful. I know that these units were added to many trailers. Can anyone help me get this pad removed?
Richard
Old 02-17-2006, 12:52 PM   #2
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Well, wish I could help you but mine fell off the wall and I had to make a new frame for it and remount it to the wall. I had evidently loosened it when I unhooked the gas line to put in the new floor. I have a 78 Argosy. The new sturdier frame is mounted back to the wall with larger screws and makes the whole assembly more rugged. I know this is not any help to you, but it is my experience with the wall heater. Perhaps it's not supposed to come apart, but come off as one unit.
juel is offline   Reply With Quote
Old 02-17-2006, 01:06 PM   #3
2002 25' Safari
Dewey , Arizona
Images: 62
Thanks anyway! The screws that mount it to the wall are behind that **** pad.....
Richard
Old 02-17-2006, 03:42 PM   #4
D E CANADA
decanada's Avatar
1994 28' Excella
Boise , Idaho
The one that was in my 74 and the one in my 97 are made with a hole for the screw to slip into and then lower the heater onto the slots that are connected to the hole. Attempt to lift the heater straight up about 3/8 inch and pull it away from the wall. Hoping that is the way yours is mounted also.
decanada is offline   Reply With Quote
Old 02-17-2006, 04:25 PM   #5
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
You're right. Now that I remember it hangs on the wall like some of the clocks you buy. Just lift up and pull out. I had forgotten that, sorry. But I was right about it coming off in one piece.
ID:	18527   Click image for larger version
Old 02-18-2006, 01:30 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
decanada & Juel, Thank you! I disconnected the propane line and lifted that sucker right off the wall. Tightened the loose screws and put it back. Thanks again!
Richard
Auxiliary catalytic heater bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-16-2006 03:41 PM
Catalytic Heater eracism Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-06-2003 07:15 PM
Catalytic Heaters - Who Wins? Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-18-2002 07:09 AM
Another Catalytic heater question Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-26-2002 10:57 AM
Olympian Catalytic Heater davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-26-2002 10:47 AM
