Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-11-2007, 09:38 AM   #1
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Taking a furnace out for extended servicing
Hi, I have a NT-30MA furnace in my 79 International that I'm thinking about removing and giving a complete overhall. During this time, I'd still like to supply gas to the rest of the trailer for hot water, fridge, oven, stove. Since there is no gas shutoff valve for the furnace that I know of, is there a way to cap the gas pipe that would normally go to the furnace during this time?
wacnstac is offline   Reply With Quote
Old 07-11-2007, 09:50 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Take a look underneath the trailer...mine has shut off valves for the individual lines. If not you could add a shut off valve to the furnace line, pull the line and cap it at the T, or cap the line itself and test to make sure it is tight.
Aaron
WBCCI #2449 AIR #2495
Old 07-11-2007, 09:55 AM   #3
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
Aaron
I would say if there isnt a shut off you should add one.
Rodney
On a magic carpet ride
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 07-11-2007, 09:58 AM   #4
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
There should probably be shutoffs for each and every propane appliance. If there aren't, add them! (It's not very difficult to do, though I did have a devil of a time locating shutoff valves to purchase when I redid some of the line on our 67.)
L
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 07-11-2007, 10:29 AM   #5
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Shut of the valve and add a flare cap to the exposed pipe when you do remove the unit. The cap will give you a 2nd plug and keep stuff from going down the pipe..
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 07-11-2007, 10:58 AM   #6
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Hi wacnstac,
As Hi Ho said, use a flair cap or plug (it's usually a plug from my experience) to block the furnace line when you remove it (be sure that you turn off BOTH LP tanks before doing this ) so you can still have the LP flowing thru the rest of the trailer.
Also, remember........NO TEFLON TAPE OR PIPE DOPE is ever used in flair fittings and be sure to order a gasket kit for the burner access cover when you take it off. They are like a piece of paper and very brittle, and you'll need a new one if you remove it during your O/H.
Have fun and enjoy 'bonding' with your furnace .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-11-2007, 12:12 PM   #7
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
So, if I'm going to replace rims, how do I figure out what offset is best. -Bernie
bhayden is offline   Reply With Quote
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
test
