Old 07-11-2007, 08:38 AM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Taking a furnace out for extended servicing
Hi, I have a NT-30MA furnace in my 79 International that I'm thinking about removing and giving a complete overhall. During this time, I'd still like to supply gas to the rest of the trailer for hot water, fridge, oven, stove. Since there is no gas shutoff valve for the furnace that I know of, is there a way to cap the gas pipe that would normally go to the furnace during this time?
wacnstac is offline   Reply With Quote
Old 07-11-2007, 08:50 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Take a look underneath the trailer...mine has shut off valves for the individual lines. If not you could add a shut off valve to the furnace line, pull the line and cap it at the T, or cap the line itself and test to make sure it is tight.
Aaron
WBCCI #XXXX AIR #2495
Old 07-11-2007, 08:55 AM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Aaron
I would say if there isnt a shut off you should add one.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 07-11-2007, 08:58 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
There should probably be shutoffs for each and every propane appliance. If there aren't, add them! (It's not very difficult to do, though I did have a devil of a time locating shutoff valves to purchase when I redid some of the line on our 67.)
L
WBCCI 21043
eubank is online now   Reply With Quote
Old 07-11-2007, 09:29 AM   #5
Central , Mississippi
Shut of the valve and add a flare cap to the exposed pipe when you do remove the unit. The cap will give you a 2nd plug and keep stuff from going down the pipe..
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-11-2007, 09:58 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Hi wacnstac,
As Hi Ho said, use a flair cap or plug (it's usually a plug from my experience) to block the furnace line when you remove it (be sure that you turn off BOTH LP tanks before doing this ) so you can still have the LP flowing thru the rest of the trailer.
Also, remember........NO TEFLON TAPE OR PIPE DOPE is ever used in flair fittings and be sure to order a gasket kit for the burner access cover when you take it off. They are like a piece of paper and very brittle, and you'll need a new one if you remove it during your O/H.
Have fun and enjoy 'bonding' with your furnace .
Old 07-11-2007, 11:12 AM   #7
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
So, if I'm going to replace rims, how do I figure out what offset is best. -Bernie
bhayden is offline   Reply With Quote
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
