Old 03-20-2016, 11:49 AM   #15
1976 Argosy 26
Fair Oaks , California
Mine was the lovely green laminate . No reinforcement needed. The backsplash does not hug the wall due to its curved nature so there is a small gap at the edge. While I was modifying the cabinet , I added a 110 volt outlet under the sink and installed a small microwave oven on the shelf. Not terribly convenient but not a lot of options. I installed a new furnace also and used 2x4 lumber to elevate it to proper height. Hope this helps.
ID:	259122   Click image for larger version
Argosy Heir is offline   Reply With Quote
Old 03-20-2016, 12:28 PM   #16
1976 Argosy 26
diamond bar , California
Thank you! I believe this is the best solution for me. Great tip for the microwave in that space, I agree very limited space. I may keep the sink but new faucet for sure.
I was told in a previous post that the new furnace would need shimming as the new one is smaller. I know each install is a bit different but at least it gives me a idea of the amount of shimming.
In your picture, the fold out shelf? I have the existing orange plastic lam top on mine. I was thinking of using the cut out portion of the new top for the oven or sink for that shelf. Is yours a butcher block? Cutting board?
909kenu is offline   Reply With Quote
Old 03-20-2016, 01:19 PM   #17
1976 Argosy 26
My sink is original as well. Cleaned up nicely. The faucet is a pull out spray type I bought at Costco . Yes , that is a cutting board. The old table was way too heavy. Bought the hinges at an RV supply and painted them a copper shade to better match. You can PM me if you have any more questions and I can provide more details .
Old 03-21-2016, 09:30 PM   #18
1976 Argosy 26
Argosy Heir, I PM'd you but the forum will not let me send you my email address. Error message, new members are not allowed to send links until they are trusted members.
Old 03-21-2016, 10:41 PM   #19
1976 Argosy 26
We were all new members at one time ....
Sent you a PM.
Old 04-05-2016, 10:11 PM   #20
1976 Argosy 26
Thanks to everyones input my new Suburban NT 30 is in. I elevated the unit off the floor to match existing vent holes. New copper K flaired to meet new gas location.
I also cut down my existing cabinetry. To accept the Home Depot countertop was really simple. I actually cut only one side about an inch and the other side of the cabinet had a lot a room to move back. It's a close fit for the furnace but worked out well.
Again many thanks
Old 04-07-2016, 12:03 AM   #21
1976 Argosy 26
How about some pictures ??
Old 04-08-2016, 10:12 AM   #22
1976 Argosy 26
Sorry, I just don't know how to post pictures. I'm trying to turn pictures right side up....Here goes[ATTACH][ATTACH]
[/ATTACH][/ATTACH]
Well is raining here right now, believe it or not. I need to clean up the trailer as you can see. I will post a finished pic.
Old 04-09-2016, 07:59 AM   #23
1976 Argosy 26
furnace pics. New vs. old size.
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 52 05-08-2018 01:31 PM
Any problems with age of Airstream in campgrounds with RV age limits? JustSomeGuy On The Road... 27 01-16-2016 11:43 AM
wire color code for nt32 c furnace Brian Casson Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-05-2013 10:23 PM
NT32 Suburban Woes obxgal Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-12-2009 07:15 PM
Suburban NT32 Maint Pick Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-16-2003 07:43 PM
