Old 05-07-2014, 05:40 AM   #1
1975 31' Sovereign
Valparaiso , Indiana
Suburban NT30SP Hot Ductwork
I just replaced the old Suburban NT32 furnace in my '75 Sovereign with a new NT30SP. The furnace works great but I am concerned that the ductwork gets so hot, too hot to touch. I replaced the ductwork with new aluminum flex identical to what was originally installed. I am also adding a 4th 4" round as recommended by a lot of Forum readers.
Should I replace the duct with insulated duct?
Ken
Boilermaker
boilermaker is offline   Reply With Quote
Old 05-07-2014, 06:30 AM   #2
r carl's Avatar
Lin , Ne
No, its just working good.
Old 05-07-2014, 10:34 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Adding a 4th duct will drop the temperature about 20 degrees.
NT30SP very hot?? pt1949 Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-24-2014 09:14 PM
Where to buy Suburban NT30SP furnace Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 10 11-29-2012 10:09 AM
Ductwork question CeloNC Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-18-2012 04:20 PM
ductwork for new Suburban Furnace adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 8 10-09-2012 08:04 AM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
