Old 09-24-2013, 08:53 PM   #1
thomdial's Avatar
1979 23' Safari
, Ohio
Suburban NT30-MA working like new
Pulling it out of my 79 Safari was the hardest part. Cleaned out the burner, checked the valve connections, and vacuumed out the rust. Reinstalled the furnace the way it should have been in the first place and voila! Heat.
Total cost= 0 dollars. Today was a good day.
thomdial is offline   Reply With Quote
Old 09-24-2013, 09:07 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
So long as the heat exchanger is intact, no worries.
I would install a carbon monoxide detector, for a little peace of mind.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-24-2013, 09:16 PM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Did you check the connection between the burner and heat exchanger?
There was a recall due to deteriorating hose connection.
Not sure the material but it kind of looks like radiator hose
Garry
Old 09-24-2013, 09:17 PM   #4
thomdial's Avatar
1979 23' Safari
, Ohio
We have both carbon monoxide and propane detectors, thankfully.
Old 09-24-2013, 09:19 PM   #5
thomdial's Avatar
1979 23' Safari
, Ohio
Yes.
Old 09-24-2013, 09:20 PM   #6
thomdial's Avatar
1979 23' Safari
, Ohio
Mine is like the one on the right.
Old 09-24-2013, 09:41 PM   #7
Ottawa , ON
You were lucky, Thom. The only furnaces I have seen from that era (including mine, that I replaced with a new one) were badly rusted out, AND had the old recalled crossover pipe.
