Old 08-30-2012, 09:08 AM   #15
1974 Argosy 20
Kooskia , Idaho
Originally Posted by Aage View Post
  1. The gasses could leak, in an extreme example. Witness the problem they had with the xover gasket on the old ones.
  2. The noise! I am fairly sure that it would wake up the sleeper above it every time it came on.
Our new one in our 31-footer is at least 8 feet away (in a cabinet under the stovetop, next to the sink) and sometimes wakes me up when it comes on.
In a space as small as an Airstream, the gases, in a leak situation, would not matter if they were under the bed or a few feet away. They would be mixed with the heating air from the fan and fully cover all of the trailer, not just the space above the bed. They are dangerous, no matter where the furnace is in the rig.
Noise is a very subjective area. Mine, in the Argosy, is a newer replacement, and is much louder than the original one. But, once my brain gets used to it, I never hear it. The sleeping brain simply says "oh that again" and seems to shut it off as an issue. If you let it bother you, however, it will.
BTW, water heaters are in the same situation, under the beds. And they often makes some noise when they run.
Suburban Furnace recall !!! NewStreamer Furnaces, Heaters, Fireplaces & Air Conditioning 34 11-26-2015 03:29 PM
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
1973 Furnace Book 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-08-2002 07:59 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
