You could have any number of problems.
First I would remove the furnace from the trailer to better access all of the components for bench testing. Check all of your wiring connections first and be sure they are clean and tight. Be sure that you are getting 12VDC on the power leads feeding the furnace. If you have a circuit board, remove the plug and clean the contact area on the board with a pencil's eraser. Then place and remove the plug a few times the clean the contacts on the plug itself.
Next, hookup the power leads to a 12VDC battery and the LP to an LP tank from your barbecue grill with the regulator in place. With everything connected, join the 2 blue thermostat leads together and see if the fan starts. If so, the unit should purge the plenum and fire in 15-20 seconds.
If it does not fire, remove the voltage and LP and look at your sail switch and test it for continuity. If that is OK, look at your limit switch and test for continuity. If that is OK, remove the leads from the gas valve and apply 12VDC directly to the valve. You should get a click that shows it is opening.
If everything is OK and you do have an igniter board, I would replace it at this point, or have yours tested at any well equipped RV shop. If you do not have an igniter board but a time delay relay (TDR), I would look into replacing that.
Hope this helps!
Originally Posted by elliottkatz
Hi Everybody,
Every fall I write on the forums here as the cold drops in and I'm forced to turn on the heater. Last year my pilot needed cleaning, and this year I have no idea how to fix the furnace. It started out like this: the furnace would turn on and heat up to the temperature on the thermostat and then would shut off. When it went to cycle again, the blower would come on for ten seconds and then would shut off immediately. It would continue to turn on and off like this until I switched off the unit at the thermostat. I thought the thermostat might be acting up because when I pulled it off the wall and "shorted the circuit" by connecting the two wire ends, the heater turned on perfectly. But now, after fiddling with the unit for another week, the bypassing trick at the thermostat ends doesn't work. I get no response from the furnace at all. After reading a number of these forums I've deduced that the problem could be coming from any number of parts in the unit... the circuit board, the thermostat relay, etc. Does anybody have any tests I could do to narrow my search? Or any other advice that would be useful for getting heat back in the trailer? In VT where it gets rather cold.
Thanks! Elliott
