12-10-2010, 09:44 PM
#41
x
XXXX
, XXXX
GGAL lets wait and see what he finds tomorrow. LC30 120 VAC/12VDC load center. This should be both the 110VAC circuit breaker and 12VDC fuses in one panel so you don`t need to keep looking for the original one. Maybe you shouls start your own thread so we don`t keep hijacking this one.
12-11-2010, 10:56 AM
#42
1969 31' Sovereign
Hadensville
, Virginia
And we have central heat! My husbands uncle came and looked at it this morning. It seems that the igniting rods or whatever you call them were corroded enough that it prevented a good spark. I've been afraid to take anything apart, but he cleaned them up, and voila! heat! We are lucky it was that easy, if only we called him earlier.
Now its time to get a bigger propane tank.
Betsy
12-11-2010, 03:52 PM
#43
1967 22' Safari
North Dartmouth
, Massachusetts
Betsy
Yeah! Betsy I'm glad you solved your problem! Igniting rods you say. I will keep that in the memory banks as I try to resolve my issues. Sorry to interrupt your thread...at first I thought it might actually help if more information surfaced regarding the heaters. Keep warm.
12-11-2010, 04:38 PM
#44
x
XXXX
, XXXX
GGAL how did you make out today. Is your converter now charging the battery and supplying 12VDC to the trailer. Does your furnace now work. was there any damage to plumbing from the winterizing.
12-11-2010, 05:11 PM
#45
1984 31' Airstream310
Ajo
It's commonly called a "electrode" and I'm sorry I did not think of it, knowing I've replaced a few!
01-15-2012, 06:14 AM
#46
1987 Excella 32'
1987 32' Excella
Kennewick
Originally Posted by bmccomb
December 7, 2010
December, 2009, I installed a new suburban nt-30sp furnace in my 1987 Airstream Excella 1000 travel trailer. It worked fine until it quit when I ran out of gas while it was operating. After refilling the propane bottles, the furnace would not come on – that is, I could hear the thermostat “click” but the furnace did nothing – no fan, nothing.
I had a repair facility look at it and they said that my pressure regulator was faulty and not providing enough pressure, even though the other appliances worked fine (stove, oven, refrigerator, hot water heater). But the new pressure regulator seemed to fix the problem as the furnace once again worked fine – until now. I have once again run out of propane and, after filling both tanks, the furnace will not come on just as previously stated. No fan, nothing!
Is there some procedure to reset a safety feature when this happens? I don’t have a gage to check the actual pressure but once again, all other appliances are working fine.
Two years later and the problem is intermittent. Sometimes I go weeks where it works fine and then one morning the fan starts but I don't hear that "click" after 15 - 20 seconds that I now think is the sail switch working. This morning that happened again so I got out my rubber mallet and smacked the edge of the furnace case several times, then tried the furnace again and it came on! It subsequently went through several cycles just fine. I'm pretty sure that a sticky sail switch is the problem. I'm trying to fine a picture or diagram of the nt-30sp showing the location of the sail switch but no luck - anyone have one?
I've also replaced the analog thermostat with a Hunter 42995 ($20.00 from Walmart) and it works great!
01-15-2012, 08:42 AM
#47
Corona
Once the furnace is removed frame the case, the location of the sail switch, which is a "microswtich", is obvious, since it will be in plain sight.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
How to start a Suburban Furnace
Steve Lou |
Furnaces, Heaters, Fireplaces & Air Conditioning |
9 |
04-07-2015 07:46 AM |
Pix of Suburban NT-30sp replacing NT22
fotochop |
29 |
02-24-2012 01:46 PM |
Suburban NT-30SP installation tip
Starscream |
7 |
10-25-2010 04:01 AM |
Suburban furnace where to start?
Pacerized |
37 |
09-12-2009 12:36 PM |
blower of suburban does not start when cranking up thermostat
turfclubroad |
13 |
09-11-2009 12:38 PM |
