Old 10-24-2010, 02:21 PM   #1
Starscream's Avatar
1976 25' Caravanner
North Charleston , South Carolina
Suburban NT-30SP installation tip
Hi everyone! I'm fairly new to the forums but since I've found so much help here, I thought I'd share my latest find.
My husband and I have a 1976 Caravanner and installed a new NT-30SP in it. Much to our dismay, the blower would start but no ignition and it would just shut down.
We found the problem today and above the gas inlet is a limit switch. (#21 in the manual) Ours also has a "Tester 1" sticker near it. My husband is not very happy with "Tester 1" but I digress....
After unscrewing the plate to take it apart, we found one of the electrical connectors was not connected. Be warned, you'll need small hands to do it.
Bring it winter! We've got heat!
Starscream is offline   Reply With Quote
Old 10-24-2010, 08:07 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Pretty good detective work! How'd ya figure that out?
Gary
Old 10-24-2010, 08:42 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Well done! There's only two things that can be serviced on the Suburban without removing the whole unit; you got one, and yes, it is a bearcat to get at that limit switch.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-24-2010, 10:11 PM   #4
Starscream's Avatar
1976 25' Caravanner
You have to have tiny hands to get at that switch! I just made the cutoff. Gary, it was process of elimination and ALOT of luck. We checked our electrical, lp, airflow. Then we worked our way back realizing that the unit wasn't even trying to light the pilot and it was shutting the blower off because there was no gas getting through to light in the first place.
It seems the simple solutions have been the best for our renovation so far and this was no different. Plug it in!
Old 10-24-2010, 10:15 PM   #5
Splitrock's Avatar
I haven't tried to light mine yet. I may be posting for help:-)
Old 10-24-2010, 10:45 PM   #6
Mike Leary's Avatar
Images: 11
Very strange, your fan shut off? I've had limit switches go out over the years and in my cases, the fan keeps blowing, only cold air!
Old 10-25-2010, 12:37 AM   #7
Starscream's Avatar
1976 25' Caravanner
The fan would blow cold air for a minute or two and then shut off. The switch itself was fine, it just wasn't plugged in. The bottom connector was unplugged. I'm wondering if maybe it was just loose before we opened it up? That might explain the fan blowing and then cutting off when the connection was lost.
Old 10-25-2010, 05:01 AM   #8
x
XXXX , XXXX
New furnaces are designed that way. If the burner goes out the fan will run for a while to cool off the combustion chamber and then the fan will shut down. That way the furnace doesn`t become an air conditioner.
wasagachris is offline   Reply With Quote
Pix of Suburban NT-30sp replacing NT22 fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 29 02-24-2012 02:46 PM
A useful tip perhaps Randjg1 Windows & Screens 0 07-11-2010 11:54 PM
Need tip for CEL on 2005 2500 Suburban Davis Tow Vehicles 13 01-28-2009 05:58 AM
New NT-30SP fires 10 sec. then goes out, fan on fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-06-2009 08:04 PM
NT-30MA to NT-30SP furnace change '79 Excella 500 SafeHarbor 1978- 1979 Excella 500 17 08-22-2007 09:36 AM
