Old 09-06-2019, 05:17 PM   #1
1990 29' Excella
Long Island , New York
Suburban NT-30K Furnace Wonít Light
The furnace in my Ď90 excella doesnt want to start anymore. Iíve owned it for about 10 years and when I bought it the owner told me to just take some sandpaper to the electrodes and it would fire right up, but not anymore.
Iím really kinda lost as far as troubleshooting this goes, if anyone could direct me to a site that could walk me through it, I would appreciate it. I think my next move is to take it out of the housing, and blow it out with compressed air, Im sure itís never been cleaned before, way overdue.
Dano73 is offline   Reply With Quote
Old 09-08-2019, 10:20 PM   #2
Vintage Only
1966 26' Overlander
1981 31' Excella Limited
1964 22' Safari
Ramona , California
I am not sure what units (year) are impacted but I suspect that furnace may be included in the old safety "recall". I had a similar vintage and had a new furnace installed. The do age and I would not sleep knowing I had a 30 year old furnace. A new one is not that expensive and meets current safety standards.
1966 Overlander, 1981 Excella II, 1964 Safari (for sale)
kenfconnor is offline   Reply With Quote
Old 09-08-2019, 11:59 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
When mine failed to light the problem was the electrode had developed a leakage resistance short that kept the voltage from building up to make a spark. Check to see if you have a spark. If not, disconnect the electrode and see if you can get a spark to the cabinet of the furnace. If you do get spark there you need a new electrode.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-13-2019, 11:46 AM   #4
1990 29' Excella
Thanks Al. I do get spark at the cabinet, and you are correct, I may need a new electrode. I think I am going to remove the heater, and blow it out with compressed air, as it says in the manual, part of routine maintenance. Lol. Make sure all the dust is cleaned up, and then if no ignition, I will replace the electrode, which is obsolete, but I found a guy that has one.
Chris
Old 09-14-2019, 11:45 AM   #5
1990 29' Excella
Took the furnace apart and cleaned the combustion chamber, and itís working again. I believe the rust buildup on the burner probably had everything to do with the ignition problem, much like chimney rust will snuff out your fridge flame. It obviously doesnít get used that much, so It appeared to be in remarkably good shape. Nice to have as a backup when camping in the cold, heats up fast, and shoots some hot air to the tanks if needed, as we try to make sure weíre plugged in if itís that cold.
Old 09-16-2019, 10:58 AM   #6
Vintage Only
1966 26' Overlander
1964 22' Safari
Ramona , California
Glad to hear you were able to resolve. Just for closure since I brought it up on this thread the recall was for much older units. 1966-1977. Details below:
Suburban initiated a recall for all furnaces made from 1966 through 1977:
Campaign : 77E-012 initiated summer of 77
Campaign : 81E-015 initiated winter 81-82
The furnaces were models NT-17, NT-20, NT-22 and NT-30 manufactured between 1966 & 1970 The serial numbers were 0064881 and lower.**Also furnaces made between 1970 & 1977 except those with an "M" suffix, The serial numbers are: 0064881 through 0715865.**The recall specifies:" if the model and serial number of your furnace falls within those noted, have it inspected unless you are VERY SURE the Suburban recall has already been completed on your unit.**The furnaces in question have a rubber-like crossover tube that could crack.**Extremely dangerous carbon monoxide would then be expelled into the interior.Ē
Furnace is acting up... NT-30k Suburban groundhogy Furnaces, Heaters, Fireplaces & Air Conditioning 0 11-30-2017 06:25 AM
Furnace- Suburban NT-30K disassembly groundhogy General Repair Forum 2 04-27-2015 10:39 PM
Furnace Ignition Problems, NT-30K Natenick General Repair Forum 14 05-04-2013 05:28 PM
Suburban NT30: Pilot Light Won't Light 2xS Furnaces, Heaters, Fireplaces & Air Conditioning 31 03-03-2010 09:26 AM
Surburban NT 30K vs. NT30SP musketeer Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-28-2008 12:55 PM
