09-18-2007, 04:45 PM
Suburban NT-30 woes
The Suburban NT-30 in my 1987 Sovereign was working yesterday but is not working today. The furnace will come on but blows cold air. The newly installed water heater works fine and I have plenty of propane. Any suggestions or thoughts on where to start with this problem would be appreciated. Thanks in advance.
09-18-2007, 06:03 PM
1993 34' Excella
Estancia
, New Mexico
I would start with the thermocouple which should have an output of about 27 millivolts. Other possibilities are the limit switch, anti sail switch, thermostat, circuit board.
Generally speaking I know enough to be dangerous and the innards of a furnace call for more technical expertise than the average Joe Handyman. You may save yourself some time and hassle, unless this is an easy diagnosis, of getting some help from a good RV guy. You don't necessarily need an Airstream tech as these furnaces are used in a lot of RVs
09-18-2007, 06:30 PM
1976 25' Caravanner
Campton
, New Hampshire
When was the water heater installed , yesterday ? Check the gas shut off valve to the furnace to see if it's open .
09-18-2007, 06:48 PM
Furnace
I had a similar problem with my 85 Soverign furnace. After two trips to the shop (which cost almost as much as a new furnace), I replaced the furnace and have had no further problems.
1985 25' Sovereign
Corner Bed
2016 Suburban
Bellingham, WA
09-18-2007, 07:02 PM
New Borockton
, Alabama
I like Marshall's answer and I would probably check them in that order.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-01-2007, 01:38 PM
Had my furnace bench tested and turns out it need's a new gas valve. Where is the best place too purchase a Suburban NT30SP?
10-01-2007, 02:05 PM
1987 34' Limited
1987 34.5' Airstream 345
Tyler
Suburban furnace
Hi! If you watch e-bay you can find a bargan on a new unit....I found mine for about 60% of retail + freight.
Pete
10-01-2007, 02:21 PM
Thanks Pete
I been watching E-Bay,nothing interesting so far, Camping World has a good price if you are a club member but they say that the unit must be installed by a qualified tech.The search continues.
10-01-2007, 02:26 PM
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia
, Alabama
Try PPL Motorhomes in Houston, TX.
They have some great prices on parts. Thats where I got my water heater, and my new rear furnace.
Rob
10-01-2007, 03:38 PM
1976 25' Caravanner
Campton
, New Hampshire
Originally Posted by dano
Thanks Pete
All part for appliances say that , depends what you are comfortable with doing yourself.
10-01-2007, 04:12 PM
Naples
Thanks Pete
dano,
The 'qualified tech' designation refers to someone who is trained and licensed in the installation of propane gas appliances. This specifically refers to opening and then re-connecting the flair connection that feeds LP to the furnace. The rest of the install is a few screws, maybe attaching ducting if you have any and connecting 4 wires.
Believe me when I tell you that most RV Techs have no real training or licensing in the handling of LP gas (especially those working at Camping World!) like I have. There are some specifics about making flair connections, but with a replacement unit, there should be only one to make and all of the necessary connection materials are already in place. It's basically wrench off/wrench on.
It's your trailer, and if you feel confident in the replacement, by all means go for it! PM me if you have any specific questions about the install.
lewster
10-01-2007, 08:00 PM
1976 25' Caravanner
Campton
, New Hampshire
Lewster
Thanks for your candid post , my opinion of at least one RV tech has gone way up .
10-01-2007, 09:10 PM
Desert Fox
1985 31' Sovereign
Tucson
Hi,
10-12-2007, 07:54 PM
Thanks to everybody who replied, I bit the bullet and bought a new furnace, the install was pretty easy, just need to install the vent cap and I'm done.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Electrical woes
'Streamer |
Electrical - Systems, Generators, Batteries & Solar |
40 |
10-21-2007 09:37 AM |
Bellypan Woes
Uncle Jack |
Belly Pans & Banana Wraps |
2 |
07-02-2007 03:10 PM |
LP OPV Woes...
scooterpie |
LP Gas, Piping, Tanks & Regulators |
12 |
10-09-2005 07:45 AM |
Suburban heater woes in a '78 International LY
sladew |
Furnaces, Heaters, Fireplaces & Air Conditioning |
4 |
02-17-2005 08:58 AM |
elec woes
joel |
2 |
09-11-2003 06:49 PM |
