07-21-2010, 09:25 PM
1978 Argosy 27
Bay Area
Suburban NT-30 problems
We've got the Suburban NT-30S pulled out completely. A few questions:
It's pretty rusty. Indication to replace it? It was installed on 4-7-99.
Also, the fan would not run until I push started it, and then only slowly and super weak.
With the price of replacement furnaces slightly out of budget, anyone have any advice?
Allie
07-21-2010, 09:57 PM
Ottawa
, ON
Ten years isn't THAT old. Mine still works (sorta) and it's 36!
If the unit is still structurally strong and whole (no holes in the fire chamber) and the famous short bit of hose that dries out and falls off is still in good shape, it sounds like what you may need is a good cleaning, and to service (or replace) the blower motor.
Mud daubers and wasps love gas-fired devices, and will build homes. Look carefully at the fan housing; did you get it really clean? Could be a bad bearing, too, I suppose.
While you have it out, though, carefully inspect the entire furnace and look for rust holes or cracks. Those signal time to buy new.
Try the Google selection within the search button up top in the dark blue horizontal line. That furnace has had a lot of good discussion.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
07-22-2010, 03:48 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Furnace motor is usually about $100 new. It is fairly easy to put in but requires a long allen wrench.
07-22-2010, 07:24 PM
1978 Argosy 27
Bay Area
Got the motor out. Here goes my first $100 on the furnace....
01-15-2011, 03:54 PM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Need help getting fan out
I've got a NT25 or NT 30 Surburban. I have the unit out and need to replace fan motor because of a squeaky bearing. How do you get that sucker out?
Don't see anyway to remove cover. Needs a good cleaning also. Everything else works OK. Since it is so old, should I replace the whole thing? I'm worried that the intake and exit holes will not line up.
Thanks for the help.
Joe
Annette
01-15-2011, 04:28 PM
1984 31' Airstream310
Ajo
Has any work been done on the furnace, or is it original?
01-15-2011, 04:30 PM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
I think it is original. It matches the manual in the book the PO gave me.
Annette
01-15-2011, 04:56 PM
Ajo
If it's removed, get set for big $$$ fun. We replaced our NT-30 in 2001. Since then, the heater motor has been replaced 4 times, the gas valve 3 times, the limit switch 3 times, the ignitor board (with a Dinosaur) once, the electrode twice. Every time we fire the Surburban, I wonder what's going to go belly-up next. We winter in Arizona and the furnace gets very little use and in the PNW we only fire it in the mornings. Junk...
01-15-2011, 06:53 PM
1965 22' Safari
Vassar
, Michigan
I bought a NT 30 Surburban last spring and paid $475. Found it on line. It works great. You should be able to replace the fan motor but if not just letting you know what it will cost to replace.
Tim
TAC MI 14
Everyday is a Saturday
01-15-2011, 07:09 PM
1976 31' Sovereign
2000 33' Land Yacht
Ball Ground
, Georgia
Furnace replacement
I had a 36 year old furnace that would not work. I took it out and carried it to the RV to trouble shoot. The plug was burnt on the circuit board. They wanted $350 to clean and fix. I found a new one with a thermostat for $400 and $30 shipping. Was not much of a decision. I put it in today and it went in with little modification. I feel safer now.
01-15-2011, 07:10 PM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
How do you get the cotton pickin fan motor out? I can not figure that out.
R U saying I should by a new furnace? 4 motors would be more than the cost of a new one.
Joe
Annette
01-15-2011, 07:12 PM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Did you get a new or used one for $400. And where if you don't mind.
joe
Annette
01-15-2011, 07:41 PM
Ajo
I'm just telling all what has happened to us; no suggestions other than have it serviced by a authorized Suburban tech and replace all the do-dads I've had problems with. If it pencils out to be more expensive than a fresh furnace, buy a fresh one with warranty. I'm not sure Surburban has warranty coverage if it's not installed by a Surburban tech, might check before ordering a "good deal" on-line. We paid $600.00 + labor for ours.
01-16-2011, 02:26 PM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Got the fan out! Took out two screws in front and the whole inside slips out. Once that was out, just a matter of taking out screws to remove the motor. You do have to use a long Allen wrench to remove the fans on each end.
There was a lot of powdered rust in the housing. I have given it a fairly good cleaning.
I think I'm going to hook the motor up to a battery to see if it will chirp. I it doesn't I'm going to put it back together and install it back in the trailer to see if the cleaning stopped it.
If I go new furnace, I'm going to have to cut new holes in the side for the intake and exhaust and put a patch for the old holes unless I can turn the new one to match up.
If it does chirp, I can buy another fan motor and take my chances on the other parts lasting for a while. We'll see how it goes.
Annette
01-21-2011, 02:51 PM
Rivet Idiot
1999 34' Excella
On The Lake
, Georgia
Ordered a new fan and just installed it. Fired up the first time I tried it. Took about three hours total from removing the furnace, replacing the fan and putting the furnace back in. Lowest price on the 231165 fan was $139. Hope nothing else breaks.
Have a great weekend,
Joe
Annette
