Old 04-03-2011, 01:11 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Suburban furnace thermostat install?
I feel dumb asking this because it seems simple, but how do you wire the thermostat to control the furnace? I am connecting to the old thermostat wires, but they don't match up. Neither my Airstream manual nor the thermostat manual are much help.
adwriter73 is offline   Reply With Quote
Old 04-03-2011, 02:04 PM   #2
There are usually two wires to the thermostat. Think of them as one wire that has been cut, and a switch (the thermostat) inserted between the cut ends. One end of the wire is live power from the battery via the 12 volt distribution panel. The other end of the wire now carries switched power to the coil of the time-delay relay on the furnace, which switches on the rest of the circuitry. One terminal on the back of the thermostat may be marked as +ve for the live wire , but as the thermostat is just a switch, on the ones I've fitted, it's irrelevant which wire goes to which terminal. (If this is sometimes different, forum members will soon tell you) I hope this helps.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-03-2011, 04:37 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
Suburban Furnace Files
These are my files from my 1976 31'. My new furnace is a NT30.
SUBURBAN GAS FURNACES INSTALLATION INSTRUCTIONS.pdf
Name:	THERMOSTAT air cond.jpg
Wiring harness
Name:	Suburban furnace Trailer harness.jpg
New heater wires
Name:	Suburban furnace new wires.jpg
Old furnace pic attached
Two blue to the two blue, red to red, white to yellow
This is for my trailer maybe not for yours. Read instructions first. Maybe get qualified help if there's any questions. This is a gas appliance located in the sleeping area. This is nothing to mess up:-)
Gary
Old 04-03-2011, 04:42 PM   #4
On my trailer, the two blue wires are for the thermostat, the red is battery 12v live, and the yellow to white is ground.
Nick.
Old 04-03-2011, 11:37 PM   #5
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Thanks for the help! It looks like I have a set of wires that control a thermostat for the A/C and a second set that control the furnace. That is what was throwing me off. I think I found them. My two wires are red and gray.
Old 04-04-2011, 09:39 AM   #6
Splitrock's Avatar
I found that all the wires can be tested and mapped with a small battery charger, a jumper light, and a multi-meter.
Old 04-04-2011, 03:05 PM   #7
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Good idea.
Old 09-10-2018, 12:58 PM   #8
1974 27' Overlander
Beaver , Pennsylvania
Too many wires
I have four wires coming out of our new Suburban furnace — 2 blue, 12v, ground.
Our new Dometic thermostat has only 3 connections. I have 12v connected to 12v, ground connected to ground, but what do I do with the 2 blue wires.
Crnjaric is offline   Reply With Quote
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 04:47 PM
Suburban furnace popping... mapley3 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-11-2011 06:47 PM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 12:36 PM
Suburban Furnace Selection MDSilverado Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-31-2011 10:40 AM
Gasket source for Suburban NT30K furnace? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-13-2011 02:35 PM
