Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 02-04-2004, 08:59 AM   #1
Craig
Profile:
Suburban Furnace Replacement
I just saw that Camping World has Suburban Furnaces on sale. My furnace is dead and removed long ago. It's sitting in my garage.
My question is, is one of these models appropriate for a 1978 Excella 500?? Is it the same size as the original? And is 30k or 35k BTU the way to go??
http://www.campingworld.com/browse/p...71&prodID=1084
Craig is offline   Reply With Quote
Old 02-04-2004, 09:06 AM   #2
markdoane
Profile:  , Minnesota
Images: 59
Suburban furnace
Most furnaces I've seen in this forum are the Suburban 'NT' type, which are taller. I have the same question: has anyone installed one of these low profile 'SF' style furnaces, and are they happy with them? Thanks for your input.
Old 02-04-2004, 09:10 AM   #3
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Search it up
I believe there have been discussions on this very issue in the past. Good ol Search feature.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 02-04-2004, 09:39 AM   #4
markdoane
Images: 59
Search feature?
Smily:
More specifically, and not meaning to be obnoxious, does anyone have experience with Suburban 'SF' low profile furnace? Not looking for rehash of pilot lighting problems, bypass hoses, catalytic heaters, or gas valve problems. Just want to know if anyone has tried a Suburban ST furnace?
Old 02-04-2004, 09:57 AM   #5
Leipper
Profile:
The only real problem with a furnace replacement is that of matching the holes in the skin to the ports on the new furnace. A secondary problem is the ductwork.
For the usual NT30 replacement of the mid seventies 32 unit, you have to slide the old furnace out of its case, remove the case from the plenum below it, and then use a spacer to lift the NT30 an inch or two to line up the exterior ports with the holes. You might also need to open up the bottom vent to the plenum and block off the side vents on the furnace. The spacer usually used is a layer or two of 3/4 plywood with an apperature cut for the furnace to plenum air flow.
For the low profile units, hooking up the existing ductwork is likely to be interesting. I don't know if they have vents on the bottom.
BTW, I found a new NT30 for $350 at a surplus place. So look around and you might be able to save a hundred or two from retail sale. (might start with Ebay)
Bryan
Leipper is online now   Reply With Quote
Old 02-04-2004, 06:28 PM   #6
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
look on ebay for truck and RV supply. replaced mine and it was about $100 less than camping world. and it was shipped from suburban. pays to look around. camping world normally has the best price when on sale.
my excella 500 had a nt 30 furnace. the airstream don't let you switch as you have to match up on the vent holes. or you wind up with a mess.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 11-11-2004, 08:21 PM   #7
Ken Sands
Keysken
Ken Sands's Avatar
Profile:  1982 31' International
Clarkston , Michigan
Smile Am interested in your old furnace, blower motor,
My furnace is in good shape but I need the blower motor.
Ken Sands in Michigan ken1s@yahoo.com
Ken Sands is offline   Reply With Quote
Old 11-11-2004, 10:27 PM   #8
mcneon
mcneon's Avatar
Profile:
See this thread for more info:
http://www.airforums.com/forum...eferrerid=2627
Replacing an original NT Suburban with its modern equivalent isn't hard, but there are some minor fit issues that have been mentioned already. All of the current NT furnaces are the same physical size, which simplifies things. As I mentioned in that other thread, watch out for new vs. original furnace ratings when replacing.
I replaced my Suburban NT with one of the low-profile units. It was a lot of work, but worth it to me because I wanted to relocate the furnace. My two goals were to improve some of the very inadequate original ducting and use the limited storage space in my Argosy MH more efficiently. The NT took up a big volume that's now dedicated to a huge drawer, while the new low-profile unit fit into a spot that was mostly wasted before.
BTW, I still have an almost-new NT-24SP for sale at a very attractive price.
mcneon is offline   Reply With Quote
Old 11-12-2004, 07:45 PM   #9
Ken Sands
Keysken
Ken Sands's Avatar
Hi Craig,
I am interested in your old nt 30. Please e mail me at ken1s@yahoo.com.
Ken Sands
Old 11-12-2004, 07:58 PM   #10
Ken Sands
Keysken
Ken Sands's Avatar
Hi Bob
I am interested in your furnace, I need only the motor,if you think the application is same , would like to purchase your furnace.
thanks,
Ken1s@yahoo.com
Old 11-13-2004, 11:48 PM   #11
Margo Schock
Profile:
I am interested in purchasing your NT24SP furnace - is it still for sale and how much do you want for it? thanks - Margo Schock
Margo Schock is offline   Reply With Quote
Old 11-14-2004, 07:47 PM   #12
mcneon
mcneon's Avatar
Profile:
Margo, I tried to email you but the system tells me your email is blocked.
My Suburban NT-24SP is still available for $225 plus shipping.
I have scanned the installation sketch from the furnace manual and will email it to anyone who is interested. It shows the modifications you have to make to use the modern Suburban furnace. The file is about 1 MB.
Old 02-24-2005, 08:42 PM   #13
srrobertsiii
Profile:
Bob, Am planning to replace my old Suburban NT-22A with a recently acquired NP-24SP. Would appreciate the installation sketch you mentioned and any additional help/tips you can offer. Thanks.
srrobertsiii is offline   Reply With Quote
Old 02-24-2005, 09:52 PM   #14
mcneon
mcneon's Avatar
Profile:
Sam, the sketch is in the email.
test
