Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-31-2003, 11:31 AM   #1
Craig
Profile:
Suburban Furnace Replacement
I have the original Suburban furnace in my 78 Excella 500 and it's ready for replacement. I may decide not to replace and just go without a furnace since I don't use the unit in the winter.
Can someone tell me what the correct replacement model # would be? And has anyone replaced a furnace on their own? I have a friend who does residential HVAC and I wonder if I could use his skills in replacing the unit.
Thanks!
Craig is offline   Reply With Quote
Old 10-31-2003, 11:56 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Craig,
The furnace is most likley a Suburban NT30.
It is really not that hard to replace. If you are a bit handy with tools and can be careful when hooking up the propane you are set.
The New NT 30 will swap right in.
1. Buy new furnace
2. Get to the old furnace. This can be the hardest part.
3. Pull the cover (inside), normally 2 screws.
4. With the LP off, dicsonnect the LP, and the 21 volt wiring from the isde. Disconnect or detach the ductwork from the air box
5. Remove the 2 screws that hold it to the floor, these are also in the air box. ( you may want to wait to do this until the exterior vent is pulled. Having the furnace held in place can help on its removal.
6. Remove the exterior vent center screw, You will get a new exterior cover so you should replace this too. 4/6 more screws to pull.
7. Remove the exteror vent cover and its two tubes. This is the hardest part as they are normally rusted together.
8. Then you can remove the furnace.
Reinstall is in the revverse order but you will need furnace tape to seal the furnace exterior vent. And I would be sure to have the vent installed and the furnace in place before screwing it back into the floor. Also be sure to get it all the way into the wall cutout. Airstream cut these close in some cases so it may be a tight fit.
BTW on the new furnaces the old thermostats work fine, the old plug will plug right in. The new ones look cheap and are made from white plastic. The only thing is there is a switch that you need to turn on, on the furnace chassis that access is thru a slot in the side. It is red, so it is not hard to find on install but depending on the final position it may not be accessable.
Even with my wonderful directions if you are not comfortable in R&R the gas lines or the furnace in general have someone who is do it. The $$ saved do not make it worth the loss of sleep worring over it. Propane CAN be dangerous.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 10-31-2003, 01:28 PM   #3
j54mark
Profile:
In addition to what is mentioned above, you may also need to deal with the duct to the holding tanks. On many units, including, I suspect, yours, the holding tanks are heated via an opening through the floor. There is a corresponding "knock out" in the bottom of the furnace which must be removed. Additionally, it may be necessary to provide a seal around this opening between the bottom of the furnace and the floor.
Mark
Old 10-31-2003, 01:53 PM   #4
thenewkid64
Just a member
Images: 21
Good catch Mark,
If his 78 is like my 77 was the duct that runs to the bedroom splits off with a funky Y connector to the tanks, but there could be a bottom port to the fresh water tank.
Brett G
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 20 06-29-2007 06:00 PM
R & R a Suburban Furnace Janet's Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 07:19 PM
Suburban Furnace tmeagle1 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-20-2004 07:18 AM
Suburban Furnace instructions overlander63 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-03-2003 09:26 PM
