02-03-2005, 10:40 AM
#21
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County
, Ohio
Of course as with all of the advice that is given on the forum pages, any use of said advice is at your own liability. That said, you may get away with finding someone with welding experience on iron. Such as exhaust headers. Welding cast iron can be a delicate process, but is do-able, as long as the part is allowed to cool slowly. If you are trying this yourself I have been successful by heating parts in the gas cooking grill, removing and welding that part and then returning it to the grill with the lid on so that it cools slowly.
After welding I would bench test it again to be sure that you are satisfied with the performance before you reinstall it. If you don't want to take the welding route, there a bunch of salvage yards because this furnace was used in many SOBs. I shouldn't be hard to find.
BTW, my furnace manual calls that rod or screw the main burner air adjustment rod.
Good luck!
Larry
02-03-2005, 11:25 AM
#22
1966 26' Overlander
Woodstock
, Georgia
thanks- I am no welder, so i did not know that cast iron was so tough to weld on. I hope to find another burner.
02-03-2005, 11:31 AM
#23
1989 29' Excella
Lorain County
, Ohio
You need special welding rod for doing the job on cast iron.
You can search the web for RV salvage yards. There are lots in Indiana.
02-04-2005, 09:53 AM
#24
1966 26' Overlander
Woodstock
, Georgia
after speaking with a few surplus dealers, it seems I can use my old log if I fill up the few slots with metal ( washers and jb weld was recommended) since the log has so many usable slots it should be ok according to them. Unless I find one I will try this. If I blow myself up my wife will be selling the 280
02-06-2005, 02:21 PM
#25
1966 26' Overlander
Woodstock
, Georgia
I reinstalled the furnace today, which was a chore. Getting it into the case was tough enough, but squeezing it back into the space under my kitchen cabinet was a big challenge. Took awhile to get it all the way in there and line it up with the outside vents. Once I did all that and reconnected evertything it fired right up, burned almost a perfect blue flame and put out plenty of heat.
Now a question--- when I checked for leaks there is a very small leak where the brass elbow joint goes into the furnace. If I tighten it one more turn I can't get the outside gas line onto the elbow, as its too close to the cabinet. I figure I can buy a slightly longer elbow, so it will extend out a bit more and solve that problem, but the question is do you use teflon tape on these threads? I use it for plumbing of course, but not sure if its correct for the gas lines. Thanks for all the support, I am happy to report the job 95% done.
02-06-2005, 04:17 PM
#26
1989 29' Excella
Lorain County
, Ohio
I teflon all threaded gas connections except flare and compression ring type connections. Especially dissimilar metals (iron/brass). It may be possible by placing a screwdriver between the furnace case and the elbow to gain a little clearance by bowing or bending the case slightly.
02-07-2005, 06:55 AM
#27
1966 26' Overlander
Woodstock
, Georgia
I tried the case bending..I think if I get a new fitting with a bit more length it will be easier to thread. I will try using the tape ..carefully.
02-07-2005, 07:46 AM
#28
Just a member
1978 28' Argosy 28
Lutz
Alan,
There is a special yellow Teflon tape for gas fittings, It is thicker than the normal white stuff. I have found it in the section where connection lines for gas appliances are.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
02-07-2005, 12:09 PM
#29
1966 26' Overlander
Woodstock
, Georgia
thanks! I will check that out.
07-06-2005, 09:31 PM
#30
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Ashland
, Oregon
Mine is removed...
But now i want to replace it with a new one. it was a NT 30, but i dont want to use ducts if I can help it, but my AS is a 29', so does anyone have any recommendations of brands/models that I should replace it with? I am also into saving space under the stove, but dont have to. I dont know if I should go catalytic? Please offer your advise, I'm all ears!
07-06-2005, 11:06 PM
#31
1989 29' Excella
Lorain County
, Ohio
Suburban
Albert,
I've seen a few catalytic heaters and they used a small stand alone fan to distribute the heat to the back of their coaches. If you are interested in a replacement you might try Airxcel, Inc. They are exclusive manufacturers of Suburban
676 Broadway St.
Dayton, TN 37321
423-775-2131
http://rvcomfort.com/
Larry
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
07-07-2005, 08:56 AM
#32
1970 29' Ambassador
1957 26' Overlander
Ashland
, Oregon
Thanks Ruff
Originally Posted by loudruff
Albert,
676 Broadway St.
Dayton, TN 37321
423-775-2131
Larry
Thanks Ruff, I will look into that unit. Are you saying that the fan is built into the heater, or do people put an additional fan near it to blow warm air to the back?
thanks
07-07-2005, 09:28 AM
#33
Just a member
1978 28' Argosy 28
Lutz
The way you plan to use the trailer is IMHO the determining factor in th decision to go catylic or ducted furnace.
The NT series furnaces all come in the same size box, so a smaller one will not necessarily save space. The ducting does one other thing that you may or may not be aware of. It feeds heat to the holding and fresh water tanks. If you are planning on using the coach in weather that would be freezing then you will want a ducted furnace to allow you to utilize the bath functions of the coach.
A catylic will heat the coach well depending on size of the heater and outdoor temps, but there is normally no fan associated with it. It is a radiant heater. If you want the warm air to be distributed you will need to employ a fan. I will admit a small 12 VDC fan will not have the draw of a furnace while boondocking, the fact that a vent needs to be open for the exhaust from the catylic can be at times an issue.
Brett G
07-07-2005, 10:25 AM
#34
1989 29' Excella
Lorain County
, Ohio
safety point
Brett's comment about the fan is correct. The fan is a separate component and not a part of the catalytic heater. Ventilation is a concern. I have read that opening a window, preferably not the one over the water heater vent, and opening a roof vent at the other end of the trailer provides needed ventilation and some heat distribution by convection.
You also need to think about adding a carbon monoxide detector to your unit regardless of whether you are using propane or catalytic heat source. IMO a necessary upgrade to any unit.
Larry
Larry and Lou
Air #2695
TAC- OH 2
07-07-2005, 05:15 PM
#35
1970 29' Ambassador
1957 26' Overlander
Ashland
, Oregon
Great tips guys
Thankks so much. I think for now I will employ a seperate electric heater. I dont usually camp in freezing temps, so I would hope that would suffice. Will a portable heater run off of 12V?
I will either wait to replace the NT30 with a new one, or put a nice Microwave in it's place under the stove. Anyone ever tried that?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Suburban Furnace recall !!!
NewStreamer |
Furnaces, Heaters, Fireplaces & Air Conditioning |
34 |
11-26-2015 03:29 PM |
72 Airstream International Furnace parts
loechli |
7 |
08-20-2008 07:17 PM |
Jingle Bell Furnace Fix
Pahaska |
5 |
11-19-2002 09:59 PM |
1973 Furnace Book
74SovereignInt. |
4 |
10-08-2002 07:59 PM |
Need Suburban Furnace Cover For 79/31' Soverign
montanaandy |
0 |
07-29-2002 10:54 AM |
