The MH is an 82 the model on the furnace says NT30M. I checked PPl Parts they have it listed, and the burner log # 10609 is used for all the NT models.
I pulled the log out, sucked a ton of rust and sooty particles out of the chambers, cleaned all. I also cleaned all the electric contacts. But the log itself had some of the openings rusted together. I was able to clean and open up most, but two of them now are bigger than they were as the divider in the middle rusted off. Will this log be useable again? Or are these holes too big, and it would need to be replaced?
The thing with the furnace is it only gets used once or twice a year at most as I have a roof a/c heat strip that is pretty effective..and live in GA which rarley gets really cold for long. Thanks again.
Rallys twice a year..Lots of fun, food, and aluminum.
Get a new one. You are going to get 2 (maybe 1) big flames and nothing out of the rest. If it is falling apart that bad it won't take much heat to destroy it anyway.
PPl sent me the new burner, a stainless steel model, the wrong one for my NT30 M furnace.
They are not sure the cast iron one is made anymore, looking into that. Mine is solid other than those few slits that broke, so I looking into cleaning it up, getting the slits welded shut and using it. Now that I have the furnace nice and clean, and the fan motor clean and lubed, I would like to try and use the thing as it is.
Of course as with all of the advice that is given on the forum pages, any use of said advice is at your own liability. That said, you may get away with finding someone with welding experience on iron. Such as exhaust headers. Welding cast iron can be a delicate process, but is do-able, as long as the part is allowed to cool slowly. If you are trying this yourself I have been successful by heating parts in the gas cooking grill, removing and welding that part and then returning it to the grill with the lid on so that it cools slowly.
After welding I would bench test it again to be sure that you are satisfied with the performance before you reinstall it. If you don't want to take the welding route, there a bunch of salvage yards because this furnace was used in many SOBs. I shouldn't be hard to find.
BTW, my furnace manual calls that rod or screw the main burner air adjustment rod.
Good luck!
Larry
after speaking with a few surplus dealers, it seems I can use my old log if I fill up the few slots with metal ( washers and jb weld was recommended) since the log has so many usable slots it should be ok according to them. Unless I find one I will try this. If I blow myself up my wife will be selling the 280
I reinstalled the furnace today, which was a chore. Getting it into the case was tough enough, but squeezing it back into the space under my kitchen cabinet was a big challenge. Took awhile to get it all the way in there and line it up with the outside vents. Once I did all that and reconnected evertything it fired right up, burned almost a perfect blue flame and put out plenty of heat.
Now a question--- when I checked for leaks there is a very small leak where the brass elbow joint goes into the furnace. If I tighten it one more turn I can't get the outside gas line onto the elbow, as its too close to the cabinet. I figure I can buy a slightly longer elbow, so it will extend out a bit more and solve that problem, but the question is do you use teflon tape on these threads? I use it for plumbing of course, but not sure if its correct for the gas lines. Thanks for all the support, I am happy to report the job 95% done.
I teflon all threaded gas connections except flare and compression ring type connections. Especially dissimilar metals (iron/brass). It may be possible by placing a screwdriver between the furnace case and the elbow to gain a little clearance by bowing or bending the case slightly.
There is a special yellow Teflon tape for gas fittings, It is thicker than the normal white stuff. I have found it in the section where connection lines for gas appliances are.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
