Old 03-03-2016, 05:37 PM   #15
1973 31' Sovereign
Middletown , California
A bird built a nest in the air intake of my furnace one summer. When I turned it on the first time in the fall it wouldn't light due to lack of airflow for the sail switch. Must have been a real small bird to fit through the slats on the Suburban intake grill. There is a small port on the firebox that can be opened to see if the electrode is sparking, when I looked in there I saw straw and twigs that had been sucked in from the nest and that clued me into that problem. A few other times I've got it to light off by cleanung the electrode with fine sandpaper. No spark can be a bad board or a stuck or defective sail switch. Assuming there is no bird nest of course!
ijustlee is offline   Reply With Quote
Old 03-03-2016, 07:17 PM   #16
1983 31' Excella
The Woodlands , Texas
If this is the original furnace you will want to replace it. A 33 year old furnace will get normal rust and develop pin holes which will leak carbon monoxide into your trailer. Also make sure you install a carbon monoxide detector. My 83 did not have one in the trailer. Most repair shops will not touch a furnace over 10 years old for this exact reason.
Air83 is offline   Reply With Quote
Old 03-04-2016, 03:57 PM   #17
Tin Man
LY007's Avatar
1983 27' Excella
Charlottesville , Virginia
Good points, thank you all. As much as I prefer to fix rather than replace things, if this repair is going to run me much over $250, I think I might buy a new one as I have seen the new NT-30 model for as low as $440, plus the leak peace of mind, etc.; my only real concern is if the exterior vents line up.
Steve
83 Excella 27
07 Tundra Limited
LY007 is offline   Reply With Quote
« Heater | Top | A/C Removal »
Atwood Water Heater Not Igniting k0irl Water Heaters, Filters & Pumps 10 04-09-2018 12:59 PM
Furnace not igniting... Quince Furnaces, Heaters, Fireplaces & Air Conditioning 22 11-30-2013 07:33 PM
Water heater not igniting - could it be the switch? adwriter73 Water Heaters, Filters & Pumps 4 09-02-2013 04:27 PM
Suburban NT-30 not igniting adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-26-2013 09:16 PM
Dometic not igniting and no propane adwriter73 Refrigerators 7 08-20-2011 02:21 PM
