Old 02-01-2015, 03:28 PM   #1
1969 29' Ambassador
elk river , Minnesota
Suburban furnace popping
Hi, About 20 percent of the time when my furnace lights, we hear a definite pop when the gas lights. Other times it just lights normal. And ideas? Thanks,Don
gorkster is offline   Reply With Quote
Old 02-01-2015, 03:40 PM   #2
dznf0g's Avatar
Oswego , Illinois
I've always considered it normal. Did it in my old trailer too. Sometimes the water heater does the same thing.
-Rich-
Old 02-01-2015, 04:32 PM   #3
1974 Argosy 20
Kooskia , Idaho
Often that is part of a delayed ignition of the propane. Not terribly serious to begin with but often gets worse with time. In my limited experience with it, a complete cleaning of the system, combustion chamber and burner included generally improves or eliminates it. Sometime there are problems with the exact proper location of the electronic spark ignition, assuming it has one.
On your old furnace 46 years old now, there was a cast iron main burner which commonly becomes filled with rust which causes delayed ignition. Requires a total removal of the furnace, then the burner to clean it properly.
I play a broken record here, virtually any 46 year old furnace is questionable in safety and probably is best replaced rather than repaired.
Old 02-02-2015, 07:01 AM   #4
dznf0g's Avatar
Oswego , Illinois
In a healthy system, I have surmised that wind direction and strength can lead to a bit of a delayed ignition and a pop when it lights off.
-Rich-
Suburban furnace popping... mapley3 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-11-2011 05:47 PM
Video of popping the shell off of a 64 Globetrotter everyman Repairing/Replacing Floor &/or Frame 6 12-09-2006 03:55 PM
Popcorn not popping thecatsandi 2006 - 2010 Classic (all lengths) 21 05-02-2006 10:07 PM
Breaker Popping tomriley Electrical - Systems, Generators, Batteries & Solar 8 02-09-2006 06:16 PM
popping fuse on tow vehicle Stefrobrts Tow Vehicles 14 07-07-2004 01:43 PM
