Old 05-07-2004, 01:51 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Question Suburban furnace.. need relay..
Hello everyone.. Our suburban furnace on our 1975 Argosy has a problem so our Rv tech says.. needs new relay.. or relays?? Having trouble finding these.. he says they are not made anymore.. Does anyone know anything about this? First rally is the long weekend May 22 and we may need heat.. Thanks Annie
Happycampers is offline   Reply With Quote
Old 05-07-2004, 02:07 PM   #2
LOST , Hawaii
I wouldn't go as far as say as it isn't made anymore, probably just not available through rv channels. Coil has to be 12vdc, if you know NO or NC, contact rating, and number of contacts it will be fairly easy to find. Check electronic outfits, they will more than likely have what you need.
John
74Argosy24MH is offline   Reply With Quote
Old 05-08-2004, 11:01 AM   #3
Annie1976
What model Suburban?
Old 05-10-2004, 07:26 AM   #4
1979 30' Argosy
The model # is NY 22C Will check on what ones I need today. thanks Annie
Old 05-10-2004, 09:08 AM   #5
Annie.
I believe the model you have is NT 22 C.
There is a fan switch and a thermostat relay, in that furnace.
We have them both.
Old 05-10-2004, 02:35 PM   #6
1979 30' Argosy
Thanks Andy
The info in the overhead storage says NY22C but when we checked on the furnace itself it said NT22C.. We will be giving you a call .. Thanks Annie
R & R a Suburban Furnace Janets Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 07:19 PM
Suburban Furnace tmeagle1 Furnaces, Heaters, Fireplaces & Air Conditioning 25 02-20-2004 07:18 AM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
Suburban Furnace instructions overlander63 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-03-2003 09:26 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
