Old 02-01-2004, 06:06 PM   #15
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Sandi,
It sounds like you have one of three possible things wrong.
The simple one is how is your battery? If it too low it can cause this type of trouble since the fan will not get up to speed so the furnace will not light.
The second, but least likely is that the gas valve is failing. They rarely fail. This is the device that allows the gas to enter the furnace and then light.
The third, and most likely, is that the PC board in the furnace has started to fail. The replacement cost on the board is far less than a furnace costs new.
The board can be replaced by someone who is handy and comfortable around propane, but it is worth the cost of an RV place to give the furnace a complete inspection, especially if it is the original one. Remember an improperly working or installed furnace can kill you. Either with CO silently, or one big boom.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-01-2004, 07:05 PM   #16
Snadi's Avatar
1982 28' Airstream 280
St. Matthews , South Carolina
Send a message via AIM to Snadi Send a message via Yahoo to Snadi
Originally posted by thenewkid64
Sandi,
NewKid,
Thanks for the reply. About the battery, would this be a problem if plugged in to power? Sure would be nice if it was as simple as that.
Debbie,
I intend to keep Chuck warm, don't you worry. He will certainly feel at home at the 'Barnyard'. I can't wait until the rally. You know this is my one year anniversary.
Sandi
Sandi Marshall
1982 Turbo Diesel 280 Motorhome!
WBCCI # 9316
Member SC Coastal Unit 150 and Friend of Chuck
Snadi is offline   Reply With Quote
Old 02-01-2004, 08:09 PM   #17
ke4pk's Avatar
Images: 8
Smile
On an electronic ignition furnace (suburban) the blower will start before it ignites to clear the chamber of any accumulated gasses and after it has run a few seconds it will ignite and after reaching the temp the thermostat demands, the burner will shut down and the blower will run to cool the heat exchanger.
I ddon't know what happens with the pilot light types.
ke4pk is offline   Reply With Quote
Old 02-01-2004, 08:26 PM   #18
aka buckwheat's wife...
PluffMudd's Avatar
1987 34.5' Airstream 345
Hendersonville , North Carolina
Images: 13
My vote is: CHECK THE BATTERY!
We just completed our maiden voyage on Silver Belle, and everything was going great until we set up camp in Hendersonville, NC... snow on the ground, cold, windy, night-time forecast of 18 degrees! Three boys, a dog, everyone hungry and the darn furnace won't light! The LP regrigerator won't run, all the cabin lights are getting dimmer by the minute, and we're on shore power! What's up with that? Long story short... the GFI equipped circuit breaker for the 110VAC was staying permanently tripped and could not be reset. Bypassed the GFI portion of the breaker and everything started working! This was the breaker that feeds the 110VAC to 12VDC converter. With 12VDC now properly powered we had furnace, we had lights, we had joy, we had fun, we had seasons in the sun...
PluffMudd
1987 Classic 345
"I find that it is not the circumstances in which we are placed, but the spirit in which we face them, that constitutes our comfort."
-Elizabeth T. King
PluffMudd is offline   Reply With Quote
Old 02-01-2004, 10:15 PM   #19
Snadi's Avatar
Interestingly enough, tonight we unplugged the camper to move it and the furnace came on as it should when the unit cooled to the temp set on the thermostat. This happened while we were unplugged. I waited out there long enough for another cycle of getting warm, shutting off, getting cool and starting up again after we plugged back in and, knock on wood, it worked again. I am leaving it on tonight so the real test will be in the morning!!! Maybe it just didn't like where we had it parked. If that will fix it, I will move it permanently. Thanks for the advice and I will post what happens in the morning.
Sandi
Sandi Marshall
WBCCI # 9316
Old 02-02-2004, 09:39 PM   #20
Snadi's Avatar
Unhappy
Oh well, that would have been too easy. It is still doing the same thing. I think it was a fluke that it worked once, just to get my hopes up. Guess I'll be calling the RV place in the morning to see if they can check it out on my way to the Barnyard Flea Market for the SC Coastal Unit 150 Rally. Come join us!
Sandi Marshall
WBCCI # 9316
Old 02-18-2004, 09:06 AM   #21
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
One thing I have noticed with mine, Snadi, when it does what you are observing is this, the gas valve does not shut off all the way, and a little bit of gas leaks through the burner. Once enough gas leaks through, it ignites with a POOF!. This uses up all the oxygen in the combustion chamber, and extinguishes or blows out the pilot. I have noticed that this only occurs after the furnace has not been used for a few days, and I do not have the pilot running. After the unit has run through one heating cycle, it runs ok and will run ok for days. This, of course points back to the gas valve. I do not believe the gas valves are available for the older Suburban furnaces anymore. Only remedy is a new replacement, or finding another old unit with a known good gas valve.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-18-2004, 10:58 AM   #22
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Isn't there also a mechanical device that is activated by the blower's airflow, and won't allow the gas to flow until the airflow is established? Maybe it is maladjusted, stuck, or otherwise disturbed. Mice, insects, who knows.
I am not sure if the later furnaces had this or not. I believe mine did.
Uwe
www.area63productions.com
Old 02-18-2004, 12:57 PM   #23
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
You are right Uwe, however if the gas valve itself is leaking......
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-18-2004, 01:51 PM   #24
Sandi,
Check the Polarity of your 120v system.
Mine was reversed at a shore hook-up and that caused the furnace and the univolt to hiccup.
Dick.
Navigator is offline   Reply With Quote
Old 02-18-2004, 07:55 PM   #25
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Temp. limit switch?
One other possibility, the temperature limiting switch. My switch was bad and allowed the unit to heat up the interior but when the thermostat told the fan to start up again, the fan would run and run because the circuit board had been overheated/damaged. Another new board was put in (unit overhauled 5 months prior) and a lower limiting switch put in. It solved the problem.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-20-2004, 07:18 AM   #26
Snadi's Avatar
Thanks for all the suggestions. I am going to print them and look into each of them. I was camping for the last really cold week and had to use electric heaters because of the problem I have described. Keep your fingers crossed.
Sandi
Sandi Marshall
WBCCI # 9316
R & R a Suburban Furnace Janets Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 07:19 PM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
Suburban Furnace instructions overlander63 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-03-2003 09:26 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
