Old 02-10-2015, 03:03 PM   #1
laducky's Avatar
1978 28' Ambassador
Pacifica , California
Question Suburban furance + Armstrong AC = 1 thermostat?
Hi guys! Sorry if this question has been answered before, I did several searches with inconclusive results. I just replaced my furnace in my '78 ambassador with a new replacement Suburban and I still have the original Armstrong AC. The AC unit has a knob that controls the fan speed but I believe I need a thermostat to activate the cooling itself. Can I combine the thermostats to work them both from one unit? I saw this one but it's a Dometic, so idk if that makes a difference. If this wouldn't work, does anyone have a recommendation for a compatible AC thermostat? Thanks for your input
Keep on truckin!
airstreamcalledtrouble.blogspot.com
laducky is offline   Reply With Quote
Old 02-15-2015, 12:40 PM   #2
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
ditto
And I thought I was the only one with this problem. My '76 has no a/c thermostat. Looking at the schematic I see where one could be wired in. I have no idea why Airstream did not install one.
terrencecolp is offline   Reply With Quote
Old 02-15-2015, 02:15 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My '74 Armstrong A/C unit has a knob you turn to set the cooling level. There is a scale from 0 to 7. The higher the number the cooler the temp.
Old 02-15-2015, 02:31 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
On some units the thermostat is built into the a/c unit.
My 72 has a separate thermostat, the 75 has a built in thermostat, there is virtually no difference in the operation of the unit though.
I am reasonably sure that a remote thermostat could be wired in.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 02-15-2015, 03:04 PM   #5
1981 31' Excella II
New Market , Alabama
You can get a generic thermostat from Lowe's that will operate both of them but you need some knowledge of electrical wiring. You would also need a relay to turn the compressor on and off on the AC unit. A new digital thermostat will control the AC compressor relay when set to cool and the thermostat will control the furnace when set to heat.
Perry
Old 03-05-2015, 01:55 PM   #6
1976 25' Tradewind
Tulsa , Oklahoma
Am I correct that my 1976 Armstrong's compressor runs all the time? It only has one switch; off, low, med., high.
Old 03-05-2015, 07:33 PM   #7
1981 31' Excella II
It has no thermostat?
Perry
Old 03-06-2015, 06:34 AM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It doesn't have a knob with a scale of 1-7?
Old 03-06-2015, 11:01 AM   #9
1981 31' Excella II
That is probably the thermostat. It it stayed on 100% of the time it would freeze up.
Perry
HELP, On Armstrong AC Thermostat mburgess1431 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-27-2012 01:07 AM
Fleixble gas connectors on Suburban furance? Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-20-2009 07:36 AM
74 Arogsy Replacemnt Furance buffaloman Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-12-2009 10:30 PM
Thermostat Lost 1975 Armstrong Collusion Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2007 05:31 PM
new furance or ceiling airconditioner with heat? striker Mechanics Corner - Engines, Transmission & More... 5 01-26-2003 10:03 AM
