Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-09-2007, 11:44 AM   #1
Deano69LY
Profile:  1969 27' Overlander
Colorado Springs , Colorado
Suburban Elec Ignition Question Problem.
I purchased a new 2006 suburban furnace w/ elec ignition to replace old 69 Land Yacht original beast. The "ignitor/sensor" combo (a small porcelin tube with wire element) is attached to a wire and is placed through a small hole into the burner chamber. The ignitor/sensor does not fit tightly and just hangs there. If it is placed too far in the ignitor arcs onto the face plate. if it is not pushed far enough in it doesn't spark the propane and or get enough heat to maintain operation.
Question(s) How should the ignitor fit in the hole, why isn't there an insulated gasket to hold it in the right position? What is a home fix?
I can position it to light off fine, but I am afraid if it cycles once lit it may not refire if not in the exact position.
Has anyone else had this problem?
Thanks Deano
Deano69LY is offline   Reply With Quote
Old 04-09-2007, 11:58 AM   #2
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Why not just go back to the dealer and get the missing parts? The igniter should be held in place so the spark gag is fixed. If the dealer is too far just call Suburban Tech support, 423 775 2131, and see if they will mail you the part. Suburban is not a customer oriented company but you can get through if you stay with it.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 04-10-2007, 12:23 PM   #3
Deano69LY
Thanks Howie
I will call the hotline.
However I do not think I am missing a part, just that the design is poor. I will check my owners manual.
Deano
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
Elec. problem again! davidz71 Electrical - Systems, Generators, Batteries & Solar 48 03-13-2005 05:37 PM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
