Old 11-10-2014, 08:44 AM   #1
69SlvrBelle's Avatar
1969 27' Overlander
Wrightsville Beach , North Carolina
Suburban 12 gallon water heater
Hi everyone! I am interested in finding out if anyone is using a Suburban 12 gallon water heater in their Airstream. Being the bargain hunter (cheap, frugal) I am, I have found one and wondering if it is too much water heater. Roughly 16 3/8 x 16 3/8 x 22. My Overlander had a 10 gallon Atwood in it, and the opening is 16 3/8 x 15 1/2. Price is very fair, available because the owner has gone tankless. What do you think?
69SlvrBelle is offline   Reply With Quote
Old 11-10-2014, 08:53 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The trend is smaller not larger. It would take you a 1/2 hour to heat it up or use a lot propane to keep it hot.
They are now installing small instant systems to reduce the propane use and size.
2004 Excursion 4x4
Old 11-10-2014, 09:38 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I installed a Suburban 10 gallon in my 75. It was a little bit of work reshaping the stock size hole to fit the new heater, but it was no big deal.
I am about sure that the 10 and 12 gal use the same size hole.
The heater works fine.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-10-2014, 10:58 AM   #4
1981 31' Excella II
New Market , Alabama
6 gallons seems fine for us. The water is so hot that it is probably 12 gallons of hot water. It recovers fast. Seems like you would waste a lot with a 12 unless you were stationary and liked to take long showers. If you are not hooked to sewer where you going to put all that water? I have never run out with the 6 gallon.
Perry
Old 11-10-2014, 04:15 PM   #5
1969 27' Overlander
Thanks for the words y'all. Been thinking hard on it. Price is less than a third of a new one. Mull, mull, mull.
Old 11-10-2014, 04:44 PM   #6
If you need 12 gallons of hot water to take a shower, then you need to reduce that amount big time.
It's been proven that a perfect healthy shower can be taken using 1 (one) gallon of water.
There is a formula as to how that's done.
Old 11-10-2014, 11:36 PM   #7
2007 22' International CCD
Talking Navy Showers vs Hotel Showers
Aw Andy, that's very true, but since I am no longer associated with the Navy, and wife also wants/needs long, hot showers, we had to overkill the original 6 gallon Atwood hot water system to suport our "hotel shower" bathing habits in the AS. Now we never run out of hot water, even with three long hot showers in close succession...
Besides, as I get old and more crunchy, lots of hot water on a cold morning helps get me moving. Best was when we hit the shower after a below-freezing night in West Texas last year, and it had no trouble keeping up. The old 6 gallon Atwood ran out at about mid-way through the third shower (fortunately after wife took hers!)--don't ask how I know this
A tankless was the way to go for us--I didn't want to carry 6 gallons of water on that side of the AS any longer. My concern with the 10 gallon would be sheer weight of the water inside--they get heavy in a hurry at about 7.5 pounds per gallon of water plus the tank and stuff... They also take longer to heat up and recover, plus are most likely more noisy--the 6 was loud when it came on in the middle of the night next to my head...the tankless is very quiet--barely hear the fan, and it does not run unless you are using hot water. There is a slight delay over the normal time it takes the hot water to get from the front of our AS to the rear wet bath, but we just let the water run into the lav sink until its hot, adjust to our liking, and then go for it! (Dont forget to put the toilet seat up to drain water off after you shower) The price was higher, but a happy wife is priceless, IMHO.
Consider most carefully.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 11-11-2014, 07:31 AM   #8
The Navy trains people, very well, especially how and not how to take a shower. Fresh water on a sea going ship is as precious as the fuel.
But, when it comes to making "mama" happy, especially in an Airstream, there is an entirely different library.
Did the Navy put that shower formula in writing, or just verbal?
Old 11-11-2014, 08:57 AM   #9
They modified shower systems to save a lot of water, and also did some training. Their usual method of saving water on my ship was to simply turn off the shower water supply during certain hours of the day. Since toilets were flushed with salt water this was not a sanitary issue. You learned to take very quick showers when water was available and folks were standing in line to get one.
The 'Hotel Shower' is a reference to what a sailor would take when staying in a hotel off the ship--long, hot, and very relaxing. Best was in traditional hotels in Japan--ending with a soak in very hot water in a deep tub. Wonderful during a cold, snowy winter in Sasebo, Japan.
KE4GNK/AE
Old 11-11-2014, 05:04 PM   #10
1969 27' Overlander
So, if you would please, give me a bit of information on what you are using for a tankless water heater. I have thought about one but I am finding all of them very expensive. What do you like?
Old 11-11-2014, 05:24 PM   #11
I installed a Precision Temp 550 series unit. Atwood makes a similar one, but the 550 can be had with an unpainted aluminum door, has built in freeze protection, and it just seemed to be a better design. Atwood makes lots of water heaters, but I don't see much design improvement in them over the years...
KE4GNK/AE
Old 11-11-2014, 05:30 PM   #12
Yes, it's expensive at first, by my wife needs/wants long hot showers to be comfortable in cold weather, so it was the only way to go. We also have installed one at home for the same reason.
KE4GNK/AE
Old 11-11-2014, 06:55 PM   #13
lewster's Avatar
Naples, FL , Hood River, OR
I put a Precision Temp RV-500 in my '06 19CCD soon after purchase. When you are connected to city water and sewer, there is nothing like a loooooong, HOT shower to sooth the body after a hard day's work. Never had the unit even burp! Ran perfectly during the entire time I owned it.
Atwoods are simply a licensed clone of Precision Temp. Why buy a copy when you can still get the original??
Old 11-11-2014, 07:07 PM   #14
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I used a $500 residential tankless.
Six GPM, a hot shower can last as long as the water and propane last.
Atwood 6 Gallon Water Heater crabbey1 Airstream Classifieds 0 02-13-2014 05:02 PM
Vintage Trailer Supply 20 gallon fresh water tank mello mike Fresh Water Systems 5 08-01-2010 04:37 PM
6 gallon water heater? Old Cracker Water Heaters, Filters & Pumps 4 06-10-2010 06:05 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
6 gallon?....10 gallon?.... FreshAir Water Heaters, Filters & Pumps 16 06-15-2007 04:57 PM
