Old 01-03-2006, 07:01 AM   #1
Stove relacement question
I am planning to replace the counter top in our 71 23' Safari. Are there any tricks to removing the Magic Chef stove?
Dbraw is offline   Reply With Quote
Old 01-03-2006, 10:29 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
If it is like my 73 Argosy there are 4 screws that hold it to the counter. One fitting @ the gas supply. Slides right on out...........
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-03-2006, 11:15 AM   #3
1990 34' Excella
Windcrest , Texas
Talking Just did this
Dbraw----What's awesome about replacing the stove is that airstream hasn't changed the dimensions.
We came across a deal on a brand new 2005 stove and it literally slipped into the spot where the original magic chef fit. No more pilot lights and the new stove has the brushed aluminum/stainless steel look to it. All for $200!!
Yep....it was four screws and the gas pipe. You may want to replace/repair your countertop while you have it out. Good luck!!
Mitch
Swanny is offline   Reply With Quote
Old 01-03-2006, 04:21 PM   #4
Stove Replacement
Thanks for the advice. I took it out this morning. Lot simpler than I anticipated. Took out the counter top also and now am building a new one with a new faucet. It is interesting that Airstream used a foam core plywood way back in the early seventies. Anything to save weight. Always something to fix or replace on an old Airstrea.
Dan
Old 01-04-2006, 12:23 PM   #5
walter1's Avatar
1964 22' Safari
Foresthill , California
Mitch, what brand /model of stove did you install. Thats cheaper and better than rebuilding my 64 Magic Chef.
walter1 is offline   Reply With Quote
Stove jeanarlene Stoves, Ovens & Microwaves 25 08-27-2004 08:39 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
GrandMa's Stove 77caravaner Stoves, Ovens & Microwaves 0 10-08-2002 05:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
