Old 01-01-2009, 11:02 PM   #1
catson4's Avatar
1991 34' Limited
Port Orchard , Washington
Thumbs up Starting Suburban NT35K repairs
After a lot of research, I find that the Suburban furnace in my 34' 1991 AS ,a model NT35K, is just a larger version of the one in my old 1980 Winny MH, a model NT25K.
The main difference is the NT25K has one intake and one exhaust ports while the NT35K has one intake and TWO exhaust ports. Just more BTU's and more heat.
So repairs are not that much of a problem as I rebuilt the ol' Winny one.
Suburban does NOT offer a direct replacement for this furnace so a repair is the only way to go UNLESS you are willing to remove a section of
outside skin and CUT NEW hole for the intake & exhaust ports.
As I am not wanting to do that, I opted for a rebuild.
This furnace does NOT have any screws that connect the OUTSIDE ports to the furnace. There are only 2 screws that hold everything in place.
They are both inside the front cover and screw into the floor. However, this furnace DOES have a long over-lap of the exhaust / intake port tubes with the exterior port frames.
Remove those 2 screws, disconnect the wiring, the hot air heater ducts (4) and the propane line and out she comes.
The "sail switch" was not working 100% of the time. That was the problem with this 19 year old furnace. And I do not think the "module board" was too damn good either.
Both the ECO ("Energy Cut Off" or high temp cut out) & timed delay switch are working fine and check out well within specs.
After a complete dis-assembly and cleaning, I did not get as much dirt or rust as I expected.
The first photo shows, in the left half, the rust & dirt I collected form INSIDE & OUTSIDE the furnace. The right half shows the dirt from inside BOTH fan blades. Remember this is a 1991 model that had a VERY HEAVY SMOKING P.O. & she lived in this unit for over 5 years. Both batches of gunk are less than 1/16th" deep on the paper.
NOW, the 2nd photo shows the "module board" and why I do not think it works either... A picture is worth a 1000 smokes........
I am ordering all new, gaskets, a new Dinosaur Module Board, sail switch and maybe other parts tomorrow.
I have a question for "the lewster" about this furnace. I am wondering about the "Extend-A-Life" kit from Dinosaur Boards.
But I will discuss that in another topic.
WISHING YOU ALL A "SHINY 2009"
Name:	Dirt from AS furnace 01-01-09.jpg
ID:	73272   Click image for larger version
Name:	furnace cuircut board1-01-09.JPG
Claude
One bazillion fish
1991 34' 60th Aniversary Limited Edition #008
2007 Chevy 2500 HD Duramax/Allison
One big parade float & a 40' Wells Cargo 5th wheel trlr.
"Wake each morning & Smile at the GREAT DAY you about to experience"
www.catson4ponds.com
catson4 is offline   Reply With Quote
Old 02-08-2009, 10:14 PM   #2
catson4's Avatar
1991 34' Limited
Easy repair but be carefull.
Peter Forwood
Greenville, SC
Claude
One bazillion fish
Old 02-08-2009, 11:01 PM   #3
catson4's Avatar
1991 34' Limited
Peter, sorry for the messed up message. I was adding to it and I guess I took to long a time. to get it posted. As it is late now, I will endeavor to post the info again tomorrow.
Claude
One bazillion fish
Suburban NT35K catson4 Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-07-2008 12:16 PM
Just Starting To Look SnowGypsy Full-Timing 4 02-12-2008 12:42 PM
Just Starting rick zigler Member Introductions 12 12-29-2006 06:08 AM
Starting over? propstrike Airstream Motorhome Forums 29 08-06-2006 06:14 PM
Just starting to look! Fogducker Our Community 4 01-25-2004 11:52 AM
