Old 03-11-2014, 01:48 PM   #1
1969 25' Tradewind
Ely , Minnesota
Square plenum in round opening and what IS this thing?
Ok, so I have finally decided upon an AC unit to put in the AS (Atwood 13.5). From what I can tell from the intallation manual, the apeture needs to be 14" square. Below is a shot of our central vent where I want to mount it. Outside dimensions of the vent are 14" but how does one get around the rounded corners? Do I have to cut the hole square?
On another note, about 16" to the aft of the vent, there is a little 1" diameter aluminum pipe sticking down through the ceiling (acutually roughly flush) with some odd little bob in it. What the *^(* is this?Click image for larger version
seismicfish is offline   Reply With Quote
Old 03-11-2014, 04:15 PM   #2
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I am going to guess. The factory AC option was a split system. That pipe was for the ac lines to the evaporator. The condenser was on the roof.
The new AC, just sets on the roof. There is no actual duct. You just need the square inches as required. Or your capacity will be reduced. There may be wiring hidden around the edge for the AC that comes out by the fuse box. Pull off the eucussion and you maybe find wires.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Square pegs and round holes artdeskin Generators & Solar Power 5 05-12-2013 04:33 PM
plenum questions--following Minno's '72 Living31 1970 - 1973 Sovereign 9 09-29-2012 03:17 AM
Round handle in Square hole???? PICS photocodo Doors & Locks 30 11-23-2009 04:33 PM
Round bars or square georgezink Hitches, Couplers & Balls 1 03-16-2009 11:06 PM
Round and Round She Goes thecatsandi On The Road... 21 04-03-2007 03:36 PM
