Old 03-14-2013, 02:17 PM   #1
2014 27' FB International
kirkland , Washington
Space heater hunt
Looking for a small, quiet, safety tip over turn off option, thermostat, efficient space heater for our 23' Serenity. 9x9 would be great.
Is there such a thing?
Searching on Amazon for the Prime quick delivery.
Any clues?
THank you
adiben is offline   Reply With Quote
Old 03-14-2013, 02:30 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Mine is 10x10, that's the best I can do for you.
King Electric Heaters and Thermostat
Quality is a little uneven on these, apparently, as my first one rattled and tended to shut off due to the high limit tripping when it shouldn't have. They replaced it under warranty.
There are places that sell the online but you'll have to look around.
Old 03-14-2013, 02:33 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Here's another one you might like. I don't have one of these and can't speak to the quality.
WEST MARINE Portable Cabin Heater at West Marine
Old 03-14-2013, 02:54 PM   #4
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We have a cube heater that we have used for quite a few years now. We place it under the dinette and it works very well.
Amazon.com: Holmes HCH4051 Compact Ceramic 1500 Watts Heater with Thermostat: Patio, Lawn & Garden
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 03-14-2013, 02:57 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Any clues?
THank you
Small and quiet do not go together. The ceramic heaters are small, but noisy. I prefer oil radiators. They are larger but completely quiet.
The ceramic heater with their (noisy) fan are better for quickly warming up. The oil radiators are slower to heat up themselves, and without a fan are also slower to warm up the area. They are great at maintaining the heat in the area once they are warm.
I've had both kinds with programmable thermostats in the past. There is a premium for the thermostat, though. Last time I bought a cheap oil radiator with only low-medium-high and a programmable thermostat that goes in the outlet on the wall. It's vastly superior to the built-in thermostats in the heater, and when the heater eventually fails, it's a separate unit. It's truly programmable, not just a digital thermostat too. You can have it turn down at night, use different settings for weekends, etc.. It would also work with a ceramic heater. In fact, it can be used for a small window AC unit in its cool setting mode.
As far as the heaters go, they all put out the same amount of heat regardless of type or brand. They are all limited to 1,500 watts maximum.
I have looked at Amazon and other locations, but in this case, you might as well go to WalMart or Home Depot. Not only will the prices be as good, but you can see what you are actually getting.
Vaughan
Old 03-14-2013, 02:59 PM   #6
1963 19' Globetrotter
Moline , Illinois
I too would suggest one of the ceramic cube heaters we use one and it does a fine job at a minimal cost.
63air is offline   Reply With Quote
Old 03-14-2013, 03:03 PM   #7
2010 27' FB Classic
N/A , Texas
I'm just dropping in to bookmark this thread. I am on the hunt for a small heater too.
Mine went belly up in a bright flash and smoke last Winter.
I've been thinking about the classic 4 ceramic disc type, but have yet to purchase.
Old 03-14-2013, 03:05 PM   #8
2010 27' FB Classic
N/A , Texas
I must have been typing while you were. What brand do you have?
Old 03-14-2013, 04:29 PM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Dyson Hot Heater thread
This is a superior heater with price to match, but worth it to those who have used it. Here's a thread about it, progresses from skeptical to satisfied users, including me:
http://www.airforums.com/forums/f427...ter-84353.html
doug k
Old 03-14-2013, 04:49 PM   #10
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Just a side note on the oil filled heaters. We place a small 8 inch fan behind it. It helps to get the air moving around a bit, for more even warming.
Silverflames is offline   Reply With Quote
Old 03-14-2013, 08:59 PM   #11
2010 27' FB Classic
N/A , Texas
doug k
Just read that thread. Looks like I'll be on the lookout for the Dyson on sale.
Thanks!
Old 03-14-2013, 11:51 PM   #12
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
We use a little ceramic heater, 29 bucks or so at Osh. Works fine for our small trailer but the noise is annoying. I like oil heaters but they're too big.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-15-2013, 11:38 AM   #13
50KIP's Avatar
2009 19' International
Woodinville , Washington
I have a small 120VAC less than a cubic foot in size to use when I have hookups (that i campground hookup) that cost about $20. I also have a Mr Heater Buddy 4000-9000 BTU propane heater for when I'm boondocking. About a cubic foot in size. I don't need to heat a large space in 19' trailer. With all the smoke, propane, and carbon mo detectors I feel safe. About $75.
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
50KIP is offline   Reply With Quote
Old 03-15-2013, 12:37 PM   #14
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
We have had this heater for a couple of years -- it has been great.
Amazon.com: Lasko 754200 Ceramic Heater with Adjustable Thermostat: Home & Kitchen
It is very quiet, and did a great job in keeping our 25 Safari nice and toasty. I have been using it in our new 27 Classic, and it has been doing the trick. I use the furnace for about 10 minutes to do the initial warm up then turn on the little ceramic (although you don't have to).
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
