Old 12-19-2018, 06:56 PM   #1
1966 22' Safari
Fredericksburg , Texas
Soundproofing Material
We are renovating a 55 Flying Cloud and are installing a Dometic Blizzard split AC. The compressor is located under the rear bed. I will use 1” isolators under the unit, but need to use a sound proofing material around the sides and top of the compressor. Has anyone had experience with materials that would work for this application? Thanks
Bubba L is offline   Reply With Quote
Old 12-19-2018, 08:21 PM   #2
rideair's Avatar
Bubba L,
Start off reading information about sound/temp control here:
https://www.sounddeadenershowdown.com/
I've then used the following products in the floor, doors and roof for sound/temp control on different projects.
https://www.amazon.com/Noico-deadeni.../dp/B00URUIKAK
https://www.acoustimac.com/soundproo...SABEgJp_vD_BwE
https://www.ebay.com/i/131754566187?...r=431129497605
Most people do not understand there are many things that go into sound and temp control.
If done right, you will be happy camper!
Paul Waddell
rideair is offline   Reply With Quote
Old 12-19-2018, 08:32 PM   #3
1966 22' Safari
Thanks Paul. I’ll read up on the links and see what I can come up with. Appreciate the input.
Old 12-25-2018, 11:35 AM   #4
rideair's Avatar
Bubba L,
Let me know what you think and if you have any questions after reading up on the links I provided. There's some really good info there that can be used in many ways.
Enjoy,
Paul Waddell
Old 12-25-2018, 12:34 PM   #5
1966 22' Safari
Thanks Paul, I would like your input to make sure I am interpreting this correctly.
Do I attach the sound deadening tile directly to the compressor to help deaden vibration noise then use a decoupled mass loaded vinyl around the inside of a box I build to surround the compressor and create a sound barrier?
Or would it be better to sandwich the mass loaded vinyl between foam board to build the box?
Your thoughts would be greatly appreciated.
Soundproofing bedroom windows TincanRitz Upholstery, Blinds, Walls & Interior Finishes 1 09-21-2015 09:38 AM
Awning material source NASCAR345 Awnings 6 03-03-2003 11:12 PM
Looking for some good reading material!! John Off Topic Forum 14 02-25-2003 10:02 AM
Soundproofing thenewkid64 Airstream Motorhome Forums 5 03-15-2002 07:12 AM
