Old 08-22-2010, 06:47 PM   #1
TankerIP's Avatar
2002 22' International
Smile Solved: Air Conditioning Drip Hose Clogged
A few days ago we parked, plugged in, turned everything on, got the chairs out and set out to relax. That's when I noticed water dribbling out the lower refrigerator external vent. I jumped to check the frig thinking it was off and defrosting. When I opened the vent door, the floor was covered with 1/4" of water. Having recently had partial floor replacement at JC last fall, I was totally worried. When I went inside the wall on the curb side was wet (we have that covered fabric wall), and there was now a slight drip from the AC. This was bad....I am definitely paranoid about any water inside the trailer
The Solution: I took the inside cover off of the A/C. I was happy to see the drain tube is plainly visible and held in place by a hose clamp. I got a screwdriver, removed the clamp --- lots of water came out that we caught in a bucket. Fortunately, I have in my truck left over clothes line wire that I was saving for some occasion. This gave me a perfect "rooter" to snake through the drain hose and out the end at the wheel well. I put everything back together and we were fixed.
One concern....what if we had turned everthing on, got in our truck and run off somewhere. We would have had a real mess by the time we got back because all the water was going inside the trailer, mostly down the wall behind the A/C and to the floor below. Lesson...check your drip hose.
TankerIP is offline   Reply With Quote
Old 08-22-2010, 09:50 PM   #2
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Mine clogged while I was at the beach last week. I had to go lay on the ground and use some home made air pressure to blow it open. It worked. It was a better experience than trying to syphon gasoline up a hose! Now I need to pull the AC apart and clean out the pan as what ever was there, is still up there I would think.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 08-23-2010, 05:47 AM   #3
Kevin245's Avatar
Good point. Drip pans can be a haven for slime/mulm and your suggestion is a great maintenance tip as we tend to ignore this until a backup such as yours occurs. Glad to hear that you caught it early and (hopefully) didn't suffer any long term harm.
Kevin
Eleanor Roosevelt
Old 08-23-2010, 09:05 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Ha! I did the "homemade air pressure" myself, one time. Hope not to do it again.
Good job, Soyboy.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
water leak, air conditioning
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Air Conditioning help Chipster Furnaces, Heaters, Fireplaces & Air Conditioning 17 08-29-2007 07:16 AM
New AS Air Conditioning - Does It Work? DreamStream Furnaces, Heaters, Fireplaces & Air Conditioning 14 02-27-2004 07:01 PM
AC drip hose Tin Hut Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-20-2003 08:30 AM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 08:58 AM
