Old 11-13-2019, 10:33 AM   #1
2017 19' International
Tallahassee , Florida
Snowflakes from the heat pump ...
Went camping over the weekend ó spectacular weather, great time to be out with an Airstream ó and when it got cool we used the ACís heat pump, but only briefly.
When we turned on the heat pump, it sent very small flakes of something out of the AC vents and all over the inside of the Bambi.
This is a 2017 19-footer. The air conditioner quit earlier this year (a few weeks before the warranty played out), so this is a brand new unit.
In the summer we ran the AC unit once, just to make sure it worked. No problem.
This is our first time using the ACís heat-pump function.
What could the tiny snowflakes be?
WhereStream is offline   Reply With Quote
Old 11-13-2019, 10:39 AM   #2
1981 31' Excella II
New Market , Alabama
If it was cold enough outside then they are indeed snow flakes. The way a heat pump works is it takes air from the outside and extracts heat from it making it even colder. It does this to the point where the outside coils start to freeze. At which point is usually does a reverse cycle and heats the outside to melt the ice while blowing cold air into the trailer. Most larger heat pumps have resistance heaters that heat when this reverse cycle happens and when it is too cold for the heat pump to do much. Usually they stop working well around 40 degrees. Personally, I think an AC with a resistance heater is a better option than a heat pump because of these issues. Also the more damp outside the faster it freezes up.
Perry
perryg114 is online now   Reply With Quote
Old 11-13-2019, 10:45 AM   #3
2013 20' Flying Cloud
Westerly , Rhode Island
Ducted ac? Many reports of the white flakes. Most likely shavings from cutting the ductwork that remained in the ducts. If you have ever cut pvc pipe with a chop saw you know how the shavings cling to the pipe due to static charge.
smithcreek is offline   Reply With Quote
Old 11-13-2019, 02:37 PM   #4
2017 16' Sport
Canyon Country , California
Wow. A snow maker!!
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 11-13-2019, 03:35 PM   #5
It wasn't all that cold, so I doubt it was real Airstream-generated snow, and they didn't melt.
This is ducted vents. We have run the AC before a number of times with no snow or rain, just wind.
Old 11-13-2019, 08:15 PM   #6
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I've seen it before in the newer ducted units. Eventually the snow stops. If it doesn't, maybe I can invent a snow shovel for duct snow.
Old 11-14-2019, 11:02 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Jingle Bells Jingle Bells Jingle Bell Rock - I'm dreaming of a white Christmas
A song for every occasion
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Heat pump or heat strips? coolwhip40 Furnaces, Heaters, Fireplaces & Air Conditioning 17 05-03-2018 10:27 AM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 08:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 03:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 10:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 05:23 PM
