Old 09-18-2011, 03:09 PM   #1
2012 23' FB International
Hollister , California
Smelling the heat!
Using our Inter 25'FB for the second time since purchase (new), turned on the heater to the acrid smell of God knows what. No smoke visible but the smoke alarm went off. Checked outside at the furnace and no smell no smoke. Over head a/c fan working. Any ideas? Used the unit last week with no problem.
Luftnoggin is offline   Reply With Quote
Old 09-18-2011, 03:19 PM   #2
dznf0g's Avatar
Oswego , Illinois
Pretty normal for a new furnace to have a hot steel/oily smell for the first few uses. BUT, I can't smell what you smell from here, so if you don't think it is the manufacturing oils burning off, get it checked out.
Old 09-18-2011, 03:19 PM   #3
Max Well's Avatar
1971 25' Caravanner
Olathe , Kansas
Check inside the heater for wasp nests or cooked critters. I bet something crawled up in there and either died or for sure is dead now!
"Surrender is not in our creed. Let me hear you say that..." Gunny Hiway
Max Well is offline   Reply With Quote
Old 09-18-2011, 03:19 PM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
That is a natural occurance for a new unit. During the walk through didn't they tell you to run the furnace for a while to burn off the mfg. residues with the doors and windows open?
Ahab is offline   Reply With Quote
Old 09-18-2011, 03:20 PM   #5
dznf0g's Avatar
Oswego , Illinois
Re-read your post. Are you talking about the heat pump, heat strip or your gas furnace?
Old 09-18-2011, 03:39 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Could it be...?
I really don't know the original equipment on anything newer than 1966....However, you might be reminded of the Carrier recall...
http://www.airforums.com/forums/f427...all-60146.html
Old 09-18-2011, 04:04 PM   #7
dznf0g's Avatar
Oswego , Illinois
That's exactly why I asked for clarification. When OP states overhead fan working, I got worried we weren't talking about the gas furnace.
Old 09-18-2011, 06:15 PM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Don't forget some dust settles on the furnace when it's not in use...when the hot parts heat up, you're going to get a smell as it burns off. That should only happen the first time or two it cycles on, though.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-18-2011, 10:55 PM   #9
Dat smell
Thanks all for your responses. Used the heater last week for the first time without any(!) smell. On start- up today, this quite acrid odor was emitted, without visible evidence, but it did set off the smoke alarm. Later today I opened all windows and vents, turned on the furnace and had the same smell and set off the alarm with the trailer fully vented. Going to let the dealer deal with it. Oddly enough I had another warranty issue as the small bedroom window exploded on opening it upon arrival at our destination. So a twofer this weekend. Having a blast (cold blast) none the less.
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
Ignitor Carbon, Poor Heat linc54 Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-30-2011 06:09 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
Need new LP heat source for short bursts of winter use pyrenees Winter Living 12 01-04-2011 08:41 PM
