Old 11-16-2009, 11:42 PM   #1
connorsa's Avatar
1999 34' Excella
Durango , Colorado
Small floor electric heater
What has anyone used to augment the furnace heat during the evening hours in the living space? Just a small floor heater that I would not leave on during sleeping hours or while I was away. Would like to pick up something inexpensive locally. Suggestions?
Thanks, Anne
connorsa is offline   Reply With Quote
Old 11-17-2009, 12:11 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Oil filled heater.
Hi, this is what we use; An oil filled heater. No fans, no noise, no air depletion, and no glowing. Mine is a Kenwood, but most of these are Delongi. [same exact heater] Lowes, Home Depot, Bed Bath & Beyond, and Amazon.com.
Name:	IMG_0242 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-17-2009, 12:17 AM   #3
c177tx's Avatar
2008 19' Bambi
Images: 20
Just so happens I went by Lowes tonight and picked up a small ceramic electric heater for 19 bucks, it has several safety fetures, tip-over safety switch, auto-off, the housing is cool to the touch, I have had it plugged in under the dinning room tabel, it is 42 degrees outside, the inside temp in my Bambi is now 73 degrees the heater is on low temp, the heater has two three settings, fan only, low heat 400 watts, and high heat 1500 watts, it has a thermostat. I have only had it for one night but so far pleased with its size and warmth. I just wanted something that would take the chill off and not have to run the duotherm AC heater as it can be a little loud even on low, this little heater is quiet and small, and while hooked up to shorepower, I do not have to use my LP supply until it gets colder.
here is a link.
Feature Comforts at Lowe's: Compact Ceramic Electric Heater with Thermostat
c177tx is offline   Reply With Quote
Old 11-17-2009, 02:30 AM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We use a small electric ceramic heater as well...it's perfect...a fairly quiet fan, a thermostat, no really hot surfaces, low and high heats...compact...and does a nice job... I think we got ours at Ace or Target...this is the season to get them at very good prices...and they have many to choose from.
One note...if it's REALLY cold and you need to protect your tanks from freezing, using a heater like this will not help them...the furnace, however, will blow warm air into the tank areas to help keep them from freezing..not really a problem, though, unless you're down in the teens for sustained periods, I wouldn't imagine...
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Old 11-17-2009, 09:34 AM   #5
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Thanks, Anne
Anne...We were using a ceramic heater but found that they can get loud when they are on their high heat setting. We now use a Vornado VH-2 heater which is very quiet and has a thermostat to control the temperature. We have no problem leaving it on when we're sleeping.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 11-17-2009, 10:03 AM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Ditto on the Vornado. We also use it in our sunroom when we are not camping.
Pat
pmclemore is offline   Reply With Quote
Old 11-17-2009, 10:19 AM   #7
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
They are rather bulky, but the liquid-filled radiators work great for us. It was 18 in Flag last night and we only turned on the Suburban when we got up. No noise at all.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-17-2009, 11:15 AM   #8
Crusty's Avatar
1992 34' Excella
Pelonis Disc Furnace
Those ceramic disc heaters manufactured by Pelonis are a best buy according to Consumer Reports and mine will run me out of the front half of my 34' if I set it too high. I bought mine on Ebay.
Crusty
"If you come to a fork in the road, take it."
Austin, TX "Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 11-17-2009, 06:40 PM   #9
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
We also bought a Vornado. Costs a bit more than the little ceramic heaters, but we go thru those about one a year in my home greenhouse. They just don't last. The Vornado warms the furnishings and you, not the air, and they work much more efficiently, without the noise of a fan. We noticed that in our Argosy the temperature was the same at the ceiling as it was at the floor, and the same in the dinette as it was in the bathroom, with no hot and cold spots, using the Vornado. It's a different kind of heat.
We have also gone thru several oil-filled radiator heaters in the last few years, they don't seem to have a lot of longevity either and they still leave a lot of hot and cold spots.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Old 11-17-2009, 06:58 PM   #10
1986 31' Sovereign
Miami , Florida
We have a little Holmes ceramic heater (a box about 8"x8"x10"), has a thermostat and two fan speeds. Most nights in Yellowstone Park last Spring (avg about 35 degrees) it was all we needed.
Saved a bunch of $$$ on propane....
mike
Old 11-17-2009, 07:02 PM   #11
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We got a Lasko ceramic heater on Amazon for about $25. Two wattage settings, fan, thermostat. It's fairly quiet, a lot quieter than the furnace. it's really small. We use it in the living/dining room/kitchen so the bedroom stays cool. When the temp goes below 32˚, we turn on the furnace. In the past we used the heat pump, but it runs very inefficiently below 40˚.
Gene
Old 11-17-2009, 07:04 PM   #12
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
I use the oil filled as well....
Al
Alwhisman is offline   Reply With Quote
Old 11-18-2009, 12:20 AM   #13
connorsa's Avatar
1999 34' Excella
Durango , Colorado
Great responses and suggestions. Thanks! You have totally answered my question. Must do something to help with the LP cost as well!
Anne
Old 11-24-2009, 08:14 PM   #14
1974 25' Tradewind
Monument , Colorado
Electric Heater
Does everyone run their electric or oil filled heaters off of generator power? All night? I've been thinking about a small Vornado myself. However I don't have a generator...just solar power.
Could I run this from a separate 125 amp/hr battery, on low (400 watt) with a portable 800 watt inverter? How long would my battery last do you think?
seeflash is offline   Reply With Quote
Identity of small floor duct flyflinger Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-15-2009 07:53 PM
Floor rot in small spot! Anniedog Repairing/Replacing Floor &/or Frame 3 06-29-2008 01:31 PM
Using a small electric heater J Goertzen Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-05-2005 06:36 PM
electric floor heating remcolent Floor Finishes 6 11-11-2003 04:12 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 02:30 PM
