Old 11-24-2009, 07:23 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by seeflash View Post
Does everyone run their electric or oil filled heaters off of generator power? All night? I've been thinking about a small Vornado myself. However I don't have a generator...just solar power.
Could I run this from a separate 125 amp/hr battery, on low (400 watt) with a portable 800 watt inverter? How long would my battery last do you think?
We use a catalytic heater in our trailer. It doesn't use any electricity, only LP. We do have an oil-filled radiator for use when hooked up to 120 volts, and we don't have to pay extra for the electric.
Old 11-24-2009, 07:44 PM   #16
2000 34' Limited S/O
Jamestown , North Carolina
I just bought the Vornado DVTH Digital which is 750 or 1500 watts. We have 15 amps where we store and I wanted something with a thermostat I could run on the late fall nights that sometimes dip below freezing so I wouldn't have to winterzie early. Someone on the forums suggested this heater which would pull less power and still prevent pipes from freezing. There are many times we can head to the beach for a long weekend this time of year. We are going tomorrow in fact.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 11-24-2009, 07:53 PM   #17
2005 31' Classic
Gretna , Nebraska
Quiet Heater
Ditto on the Vornado...
16595 is offline   Reply With Quote
Old 11-24-2009, 09:45 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, using a heater is usually at night, unless in really cold areas. [then I would run my heater 24 hours] So I would use my furnace if I didn't have shore power. I would use my furnace in freezeing weather. I use my oil filled heater in cool temps when I have hook-ups. I would not run my generator at night at all and running a generator for an electric heater would burn more fuel dollar for dollar than useing a propane furnace. I don't have actual experience with running a heater off of a battery system, but I'm sure it would drain your batteries very fast.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-24-2009, 10:52 PM   #19
1974 25' Tradewind
Monument , Colorado
Portable electric heater
Thanks for the information.
Doing the math, if you run a heater at 400 watts you only use 3.4 amps/hr (slightly more than a 20k BTU furnace) x 8 hrs. = 27.2 amps. Or 750 watts @ 8 hours = 50 amps. Recharging my battery with solar at 2 amps/hr all day should put back about 20 amps.
Seems that it may work, but I'm just not sure if my calculations are entirely correct. I would rather not use a catalytic heater as I mostly camp at high altitudes and am worried about oxygen depletion.
If anyone can shed some light on the subject matter I would be grateful.
seeflash is offline   Reply With Quote
Old 11-24-2009, 10:54 PM   #20
tpi
Trabuco Canyon , California
It is much less expensive to burn the propane for your furnace than use a portable generator to run electric heat. The cost of electricity from a portable generator is in excess of $1.00 per KWH.
Your 400 watt electric heater draws roughly 40 amp hours per hour. It draws 10X amps at 12 volts compared to 120 volts. You may get an hour or two out of your 125 amp hour battery (not supposed to completely discharge battery).
tpi is offline   Reply With Quote
Old 11-25-2009, 07:09 AM   #21
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
400 watts / 120 volts = 3.3 amps
Plus you have the inverter that uses power, so let's say 5 amps.
The battery should not be drained more them 50%, so you have 62.5 usable amp hours of battery.
62.5 amp hours / 5 amp draw = 12.5 hours
These are rough numbers and are based on a fully charged battery when you start.
Richard
Old 11-25-2009, 09:49 AM   #22
tpi
You forgot to make the 120 to 12 volt conversion on the amps. If it draws 3.3 amps at 120 volts, the inverter will draw at least 33 amps at 12 volts. With conversion inefficiency, it will be closer to 40 amps at 12 volts.
Old 11-25-2009, 10:12 AM   #23
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Anne;
some time ago I did a thread-- Heaters, heaters, heaters. You will find detailed info of different heaters. I would link it but I don't know how.
The oil heaters sound like the way to go for you, totally safe to leave on all night whilst sleeping, and there are models with built in timers. So if you are away in the day you could have a nice warm place to get home to.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-25-2009, 08:35 PM   #24
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Originally Posted by doorgunner View Post
Anne;
Here you go...
http://www.airforums.com/forums/f427...ers-29283.html
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 11-25-2009, 11:02 PM   #25
1974 25' Tradewind
Monument , Colorado
I just read the full thread the other day and that's what prompted me to ask the question. So, what is correct? Both sound logical.
My flat panel TV runs at 400 watts, plugged it into the inverter and ran it for 2.5 hr. movie with only .1 volt drop as I still had 12.7 volts in the morning.
More info. is welcome.
Old 11-25-2009, 11:36 PM   #26
1974 25' Tradewind
Monument , Colorado
Found this searching the web: thanks to all for the help.
One of the biggest mistakes made by those just starting out is not understanding the relationship between amps and amp-hour requirements of 120 volt AC items versus the effects on their DC low voltage batteries. For example, say you have a 24 volt nominal system powering a load of 3 amps, 120VAC, which has a duty cycle of 4 hours per day. You would have a 12 amp hour load (3A X 4 hrs=12 ah). However, in order to determine the true drain on your batteries you have to divide your nominal battery voltage (24v) into the voltage of the load (120v), which is 5, and then multiply this times your amp hours (12 ah). So in this case the calculation would be 60 amp hours drained from your batteries - not the 12 ah. The easiest way to quickly determine the total battery amp hours required is to first determine total watt-hours required by all loads, and then divide by the nominal DC system voltage. This resulting number will indicate the amount of amp hours needed to operate all loads for a given period. However, additional amp hour capacity would typically be added for more "reserve" capacity or to prevent complete discharge. Using the above example, 3 amps x 120 VAC x 4 hours = 1440 watt-hours divided by 24 VDC battery environment equals 60 amp-hours; the same answer as before, but another way to get it.
Old 11-30-2009, 01:30 PM   #27
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Originally Posted by 2dabeach View Post
We now use a Vornado VH-2 heater
I wonder how this smaller version would work
Vornado
Don
adonh is offline   Reply With Quote
Old 11-30-2009, 01:49 PM   #28
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
Vornado
Don
That one doesn't appear to have a thermostat. Or at least not one that you can set to a specific temp.
teagues is offline   Reply With Quote
Identity of small floor duct flyflinger Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-15-2009 06:53 PM
Floor rot in small spot! Anniedog Repairing/Replacing Floor &/or Frame 3 06-29-2008 12:31 PM
Using a small electric heater J Goertzen Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-05-2005 05:36 PM
electric floor heating remcolent Floor Finishes 6 11-11-2003 03:12 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
