Old 10-16-2011, 05:00 PM   #1
1961 28' Ambassador
St. Joseph , Michigan
Small A/C
Can you help me select a roof top A/C for a 19' 1964 Globetrotter?
The existing unit is only 29". I'm trying not to have to loose my rear roof vent with the bigger units.
Suedo is offline   Reply With Quote
Old 10-16-2011, 05:34 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
They are all set up for a 14 x 14 cutout. Just go for a an unobtrusive low profile...and go for a 15000 instead of a 13000....you won't regret it.
Ahhh...as I reread your sizing I guess your referring to the length of the units case. I had that problem on a three vent Flying cloud. After..repeat.AFTER....I had everything set for the installation of the Carrier and the unit was on the roof...I found out that the case hit the center vent cover. I had to regroup and cut (modify) the AC hole by 4 in. forward to clear the center cover. That involved cutting and bracing the roof hole. You will also have to consider the drain line.
2nd A/C for a 34' - 2002 Classic HighFlying 2001 - 2005 Classic 10 11-17-2011 07:04 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
1968 A/C not spinning fans on startup? hayduke Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-05-2011 09:21 PM
A/C Pops Breaker RichWoodward Furnaces, Heaters, Fireplaces & Air Conditioning 28 07-19-2011 05:57 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
