Old 08-18-2010, 10:55 PM   #1
2009 25' FB Flying Cloud
manitou springs , Colorado
sketchy water heater flame
Full timer in 2009 Flying Cloud. I flip the switch to my Atwood water heater in the morning 10 minutes before a shower. The unit "clicks" a few times a fires up well. Though seconds later and at random times thereafter the flame lessens and eventually goes out, then more clicks. The only time it will run uninterupted is when the access door is open. Thus, I thought adjusting vent tube to more air would help. Not so. No other adjustments that I can see.
Also, should I leave the switch and thus heater on at all times as a full timer or is intermittent use appropriate?
Thank you
movin-in is offline   Reply With Quote
Old 08-18-2010, 11:13 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have had the same problem. Remove the tube to make sure there are no bugs or webs inside of it. And you will need to adjust the tube like you already did to get a proper flame. Mine was more sensitive in cold weather at high altitudes. I did it the first time by just looking at the flame and the second time by the instructions in my owner's manual; both ways were about the same. It can be pretty touchy. Make sure both propane tanks are open so you have enough pressure at the water heater.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-18-2010, 11:16 PM   #3
Salem , Oregon
Images: 18
Hi, I used to leave mine on all the time, but now I turn it on in the morning, then off when done, then on again in the evening, and then off for the night.
2005 Safari 25-B
Old 08-19-2010, 06:36 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Before you start disassembling blow out the burner and burner tube. That may solve your problem.
seeking flame tube - '64 Bowen water heater biopig Water Heaters, Filters & Pumps 3 05-06-2010 07:03 AM
adjusting flame on Water Heater joe3957 Water Heaters, Filters & Pumps 2 09-26-2008 06:23 PM
Adjusting flame on water heater Dan S Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-30-2007 06:37 AM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Suburban water heater (might) flame on 74Argosy24MH Water Heaters, Filters & Pumps 0 05-25-2005 02:51 PM
