Old 08-13-2011, 07:45 PM   #1
Images: 18
Selling Dometic 15K Penguin
Hi we just pulled this off of our Airstream to replace w the same one except w electronic thermostat. It works great but as it is manual, we didnt want to have to leave it on all day for our comfort and cat. We are in Austin if you would like to make an offer and pick it up. We are ready to get rid of it so all offers welcome.
~Yevette
yve79 is offline   Reply With Quote
Old 08-13-2011, 08:35 PM   #2
1975 31' Sovereign
Brownsville , Texas
More Info Please
Greetings,
I'm not in Austin, but my brother-in-law is. Can you give me more info. How old is it? does it include the in side unit? Is all working as it should?
rkuhns956 is offline   Reply With Quote
Old 08-13-2011, 08:51 PM   #3
Images: 18
There is nothing wrong with it and it has worked well for us. It is the complete inside and outside unit, sans the belly pan that the outside unit sits in because we left it in place for the new unit. It just has manual controls so it is either on low, high or off. We would go to bed with it on and wake up freezing. The one we swapped it out for automatically adjusts to keep the temp you set. Most likely in the Texas heat it will run all day long but it will cut off at night.
We are not sure how old it is but can only assume it is as old as our airstream we pulled it out from, which is a 94.
Old 08-14-2011, 08:29 PM   #4
1975 31' Sovereign
Brownsville , Texas
I'm interested
I'm interested, but not sure what it is worth. I will see what it might be worth and get back with you.
Need help on installing Dometic RM100 fridge door seals carol4266 Refrigerators 3 03-24-2017 10:21 AM
Dometic Penguin or Coleman Polar Cub for 1967 Caravel?? vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 20 08-13-2011 06:10 AM
Parting our Dometic RM 75D refer. buffaloman Refrigerators 0 07-07-2011 09:35 PM
2010 Dometic A/C hansenk Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-04-2011 08:33 PM
15K BTU Brisk Air vs. 15K BTU Penguin adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-23-2011 10:32 AM
