09-15-2019, 07:42 AM
2018 27' Flying Cloud
Aubrey
Screws holding filters to ceiling
I am thinking about retrofitting how the filters are mounted to the ceiling. I am thinking about installing bolts from the top through the ceiling and using thumb nuts to hold the filters up. Has anyone done this?
12-29-2019, 06:09 AM
2009 25' FB International
2018 27' Globetrotter
Tavares
Just curious if you ever did this?
12-29-2019, 08:42 AM
Sag Harbor
, New York
Are you referring to the ducted A/C supply registers, which tend to fall out?
Moosetags had problems with those:
https://www.google.com/search?q=Moos...com&gws_rd=ssl
Peter
PS -- Click on orange arrow in quote to go directly to this post:
Originally Posted by moosetags
We have a 2015 Flying Cloud 25FB (Lucy) that we purchased new in October of 2014. This was the first year of the ceiling vent air conditioning. The original vents were covered in a screen mesh in a metal ring with no directional or cutting off capabilities.
When Lucy was about six months old, we had her at Jackson Center. Airstream replaced the original vents with the directional vents now in use. These new vents are always falling to the floor. I have tried several fixes including using two-sided tape around the outer plastic ring of the vents. This has worked somewhat, but is nopt a surefire fix. We still have vents fall, especially when we use the heat pump.
These vents are the product of a flawed design by Airstream.
Brian
12-29-2019, 09:30 AM
Peoria
Air Register Thumb Screws
This has worked well for us:
'24 Silverado 2500 Diesel 4x4 ZR2, 2018 FC 28W (Queen) Landmark Truffle, ProPride Hitch, 3" Dexter Lift, Centramatics
12-30-2019, 04:38 AM
Aubrey
Kb7our, this is what I am looking for. Can you tell me where you got these and the size of thumb screw?
12-30-2019, 06:06 AM
Tavares
X2
Thanks!
12-30-2019, 10:23 AM
Peoria
This is a fairly easy project. The SS screws are these:
https://www.grainger.com/product/1RA...on-_-Item&rfe=
The nuts on the back side are flat SS t nuts 1/4" depth. I already had the nuts but here is an example of some (not correct size - need to search around for matching size). You can mount them upside down in the ceiling with the protrusion facing up instead of down through the hole:
https://www.amazon.com/Hillman-Group...7725969&sr=8-9
I used RTV like what you can find at Walmart (e.g. black Permatex Ultra) to secure them to the inside of the ceiling. Once the RTV dries the nuts will NOT move and are perfectly secured enough to finger tighten using the thumb screws. Use the screws to align/hold the nuts while they dry overnight.
Hope this helps!
12-31-2019, 04:57 PM
2018 27' Tommy Bahama
Marana
kb7our, are these the same thumb screws?
10 Pack 8-32 x 1/2 Inch Threads 303 Stainless Steel Diamond Knurled Thumb Screws with Straight Shoulders Right-Hand Threads SAE Flat Tip Uncoated https://www.amazon.com/dp/B07XF4WTVQ..._Qc-cEbSEQQMTN
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
