Old 02-08-2016, 05:44 PM   #1
BessieB's Avatar
1997 21' Excella
Carson City , Nevada
Screeching furnace blower
Spring is almost here and weather may be welcoming to get to work on our 1997 Excel. So on my last trip, the furnace before it gets ready to turn off goes into a screech. So do I consider what? New blower? And I assume that is up around the galley area.
Thanx,
That is the main one to start thinking about.
BessieB is offline   Reply With Quote
Old 02-08-2016, 05:54 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Replaced my motor in about 2 hours... Next time 30 minutes..
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-08-2016, 06:22 PM   #3
BessieB's Avatar
1997 21' Excella
So I need to think motor not blower, thanx,
Beth
Old 02-08-2016, 06:50 PM   #4
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
Mine did that as well. Can't recall the exact fix. I do remember it was minor.
tcrum is offline   Reply With Quote
Old 02-08-2016, 07:58 PM   #5
BessieB's Avatar
1997 21' Excella
I also think of .... Belt?
Old 02-08-2016, 08:17 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Blower motor bearings, which means you have to replace the motor assembly.
Old 02-09-2016, 12:13 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Hello Bessie
The furnace has a direct-drive blower, that is, one without a belt. There is one motor with two blower wheels, one for combustion air and exhaust, the other to circulate heated air within the trailer. Eventually the bearings fail with the first warning sign being noise.
I believe your trailer is equipped with an Atwood furnace. I believe that replacement furnaces from Atwood are available that are the same size and have the same ductwork configuration and the gas connection in the same place. Given the age of your furnace, you may want to consider replacing the whole thing.
Replacement of the blower motor is straightforward unless the blower wheels are stuck on the shaft due to corrosion.
Old 02-09-2016, 12:17 PM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I agree that your blower motor is likely failing. I also agree with Jammer's post above that suggests if your furnace is original (i.e., 1997) that you replace the entire unit rather than just the blower motor. At nearly 20 years old, it has lived a long and happy life.
Bob Martel
WBCCI# 5766
Old 02-09-2016, 12:44 PM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by Jammer View Post
I believe your trailer is equipped with an Atwood furnace. .
My 93 has a Hydroflame.
Old 02-09-2016, 12:45 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
Same sauce, different name.
Old 02-09-2016, 01:01 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
Are Hydroflame and Atwood furnaces the same?
Old 02-09-2016, 02:57 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
Hydro Flame is, and has been for quite some years, an Atwood brand.
http://www.atwoodmobile.com/furnaces.asp
I believe they were a separate entity back in the 1960s and maybe the early 1970s.
Old 02-09-2016, 04:33 PM   #13
1998 30' Excella 1000
Livingston , Texas
If after inspection, the combustion chamber is solid, and expense is an issue, and you decide to just replace the motor, here is a helpful video:
Siegmann is offline   Reply With Quote
Old 02-09-2016, 07:00 PM   #14
BessieB's Avatar
1997 21' Excella
Thanx all, showed the video and rest to hubby. Will crack the whip tomorrow and gitty him onto this project.
Beth
Furnace Blower Noise Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 22 03-01-2013 11:00 AM
Screeching Electric Stab Jack - HELP!!!!!! CMSmith Jacks, Stabilizers, Lifting and Leveling 6 08-31-2012 07:18 AM
Starter screeching! Help! realpank Argosy Motorhomes 9 08-22-2012 04:48 AM
Centramatics for the furnace blower Jammer Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-07-2010 11:03 PM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
