02-08-2016, 05:44 PM
1997 21' Excella
Carson City
, Nevada
Screeching furnace blower
Spring is almost here and weather may be welcoming to get to work on our 1997 Excel. So on my last trip, the furnace before it gets ready to turn off goes into a screech. So do I consider what? New blower? And I assume that is up around the galley area.
Thanx,
That is the main one to start thinking about.
02-08-2016, 05:54 PM
1999 34' Excella
Hillsboro
Replaced my motor in about 2 hours... Next time 30 minutes..
Peace and Blessings..
Channing
WBCCI# 30676
02-08-2016, 06:22 PM
1997 21' Excella
Carson City
, Nevada
So I need to think motor not blower, thanx,
Beth
02-08-2016, 06:50 PM
1978 31' Sovereign
Cookeville
, Tennessee
Mine did that as well. Can't recall the exact fix. I do remember it was minor.
02-08-2016, 07:58 PM
1997 21' Excella
Carson City
, Nevada
I also think of .... Belt?
02-08-2016, 08:17 PM
1993 34' Excella
Estancia
, New Mexico
Blower motor bearings, which means you have to replace the motor assembly.
02-09-2016, 12:13 PM
Wise Elder
2010 30' Classic
South of the river
Hello Bessie
The furnace has a direct-drive blower, that is, one without a belt. There is one motor with two blower wheels, one for combustion air and exhaust, the other to circulate heated air within the trailer. Eventually the bearings fail with the first warning sign being noise.
I believe your trailer is equipped with an Atwood furnace. I believe that replacement furnaces from Atwood are available that are the same size and have the same ductwork configuration and the gas connection in the same place. Given the age of your furnace, you may want to consider replacing the whole thing.
Replacement of the blower motor is straightforward unless the blower wheels are stuck on the shaft due to corrosion.
02-09-2016, 12:17 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
I agree that your blower motor is likely failing. I also agree with Jammer's post above that suggests if your furnace is original (i.e., 1997) that you replace the entire unit rather than just the blower motor. At nearly 20 years old, it has lived a long and happy life.
Bob Martel
WBCCI# 5766
02-09-2016, 12:44 PM
1993 34' Excella
Estancia
, New Mexico
Originally Posted by Jammer
I believe your trailer is equipped with an Atwood furnace. .
My 93 has a Hydroflame.
02-09-2016, 12:45 PM
Wise Elder
2010 30' Classic
South of the river
Same sauce, different name.
02-09-2016, 01:01 PM
1993 34' Excella
Estancia
, New Mexico
Are Hydroflame and Atwood furnaces the same?
02-09-2016, 02:57 PM
Wise Elder
2010 30' Classic
South of the river
Hydro Flame is, and has been for quite some years, an Atwood brand.
http://www.atwoodmobile.com/furnaces.asp
I believe they were a separate entity back in the 1960s and maybe the early 1970s.
02-09-2016, 04:33 PM
1998 30' Excella 1000
Livingston
If after inspection, the combustion chamber is solid, and expense is an issue, and you decide to just replace the motor, here is a helpful video:
02-09-2016, 07:00 PM
1997 21' Excella
Carson City
, Nevada
Thanx all, showed the video and rest to hubby. Will crack the whip tomorrow and gitty him onto this project.
Beth
02-25-2016, 04:15 PM
1997 21' Excella
Carson City
, Nevada
New motor assembly installed
Thanx all,
Hubby just finished getting the new motor assembly installed. With the help of a few videos. The furnace now does not screech. But hubby said I didn't hear him.
06-17-2017, 08:36 PM
1997 21' Excella
Carson City
, Nevada
Update on screeching furnace
