Old 07-04-2014, 03:54 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
RVP/Airxcel/Coleman MACH 8 A/C Quiet Outside Fan Ki
This may alredy have been discussed but I could not fine anything so maybe this will be of help to others. This is a current thread on the IRV2.co forum covering the noise issue with the Coleman Mach 8 AC.
I am curious is the new fan blade is being installed in current units produced for sale.
RVP/Airxcel/Coleman MACH 8 A/C Quiet Outside Fan Kit - iRV2 Forums
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 07-04-2014, 06:24 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
The last Mach 8 that I installed was in April and they had not yet upgraded the condenser fan blades.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-05-2014, 07:50 AM   #3
adonh's Avatar
1976 31' Sovereign
Lew Farber
541-490-6357
Lew just wondering if you have installed the new fan blade on a Mach 8 and if it does cut down on the noise. Thanks
Don Hardman
1976 31' Sovereign
Old 07-05-2014, 10:00 AM   #4
lewster's Avatar
Nope! None of my Mach 8 clients have complained about the noise to date, but I guess I'll have to do one and measure the dB levels to see if they really work as advertised.
Generator Size for 13,500BTU Coleman Mach 3??? dscluchfc Generators & Solar Power 26 07-28-2010 06:07 PM
Coleman Super Mach Model 6798 leaking inside AirHeadsRus Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-05-2009 12:54 PM
Any one tried a Coleman Mach 3 P.S. (Power saver) ronstory Furnaces, Heaters, Fireplaces & Air Conditioning 4 04-06-2009 02:07 PM
Coleman TSR Mach 3 Drain tube bertro Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2008 10:57 AM
Coleman Mach III gasket bkahler Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-13-2007 05:11 PM
