Old 06-16-2013, 08:36 PM   #1
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
RV evaporative cooler, 12 v.
I was wasting time on the net to look at the old style evaporative coolers for cars. (And found several of them on Ebay!) While at it, I ran across this evaporative cooler for RVs. If you live in the dry southwest, and it's not tooooo hot, maybe? Anybody ever try one?
RV Motorhome Solar Battery 12-Volt Evaporative Swamp Air Conditioning Cooler : Amazon.com : Automotive
Lynn
WBCCI 21043
Old 06-16-2013, 09:07 PM   #2
Lynn
Lynn.
I found over the years that a bad smell invades the trailer after a swamp cooler is used for a while.
Old 06-16-2013, 10:27 PM   #3
1974 Argosy 20
Kooskia , Idaho
A friend used a portable evaporative cooler in his 31' AS located in central NM where it also gets very hot in the summer. He is off grid, so regular refrigeration cooling is not really possible. He said it worked fairly well for him, but used a lot of water, something like 5 to 8 gal a day.
All those coolers need a fair amount of maintenance and a roof mounted one would be difficult to get to to clean the pads and the pan, especially if your water is at all hard.
Old 06-16-2013, 10:48 PM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I refurbished the one (TurboCool) that was original to our '66 Trade Wind. It works well.....if you like a sauna. It does use a lot of water.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-17-2013, 06:17 AM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
The downside really would be the amount of water it uses. Here in NM, water is gold, and humidity is a rare event.
Lynn
WBCCI 21043
Old 06-17-2013, 08:10 AM   #6
FreshAir's Avatar
1966 24' Tradewind
Neil
The PO installed 2 fresh water tanks totaling 40 gallons. They did mostly dry camping. 40 gallons sounds like a lot but it doesn't last long on hot days. Most of our camping is dry but in the Calif. mountains.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
