Old 06-11-2008, 09:05 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Run AC on 20 amp service?
Hello,
We're currently camped in the "electric only" section at the Bluegrass camp and festival in Nevada City. The electric service being provided is 20 amp, not 15 amp, not 30 amp. We're connected to the supply box by our 30 power cord with no extensions.
Expecting temps in the 90's later this week. Is it safe to run the AC?
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 06-11-2008, 09:16 AM   #2
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
It depends on the voltage you can get. You need a voltage meter to be sure of what you are receiving. See this post for details.
Tour of America Low voltage
Also be sure your plug contacts are nice and shiny (not corroded) and that the plugs & cords are not getting very hot during use.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 06-11-2008, 09:21 AM   #3
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
I have run our air-conditioner on a real 20 amp (left hole is a T) outlet at our house with no problem. After all, what size breaker does the factory use for your air-conditioner?
However, my batteries were charged, so there was very little draw from the converter, and the refrigerator was set on override to gas, rather than auto which would use 120VAC. Don't even think about using the microwave at the same time.
I wouldn't use an extension cord, instead used a plug adapter.
Maurice
Old 06-11-2008, 09:42 AM   #4
guy99's Avatar
Images: 16
Great thanks! Looks like I'm good to go. Voltage reading w/o the AC is 120. Plus I have an autoformer which will boost it if need be.
Old 06-11-2008, 10:28 AM   #5
Refurbished 89 Excella
DKDarrow's Avatar
Sugar Valley , Georgia
What is your voltage with the AC running? Especially when the compressor kicks in?
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
DKDarrow is offline   Reply With Quote
Old 06-11-2008, 10:36 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the voltage drops below 110 while the AC is running you are running the risk of damaging the compressor. As voltage goes down current goes up and current is heat. The older AC Airstream supplied had an indicator on the AC panel that showed when the voltage was low.
I assure you if the voltage is 120 when others turn their ACs on it will drop unless you are on a dedicated line which I doubt.
Take a fan.
2004 Excursion 4x4
Old 06-11-2008, 01:25 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Take a fan.
I had some success running one roof air on my MoHo while connected to a 20 amp circuit, but it was a dedicated line.
As HowieE states, I would be wary of operating the AC if there are others on the same line. Several units starting their compressors at the same time will cause a big voltage drop and probably damage your compressor. They are not replaceable in newer AC units and you will have to replace the entire roof air.
30 amp service at home mandolindave Generators & Solar Power 12 06-01-2008 09:10 PM
Axle Alignment & other service ?s dpandorf Axles 0 05-15-2008 10:58 AM
30 Amp service at home 68 Overlander Commercial Listings 0 07-15-2007 11:13 PM
50 amp service available mtnman Electrical - Systems, Generators, Batteries & Solar 10 04-29-2006 05:11 AM
