Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-21-2002, 11:59 AM   #15
71tradewind
71tradewind's Avatar
Profile:
Same here John ,more towards Rochester. Tom
71tradewind is offline   Reply With Quote
Old 07-22-2002, 02:35 PM   #16
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
A/C replacement
Frank, (and Brett)
I replaced my old Duo-Therm with a newer used Duo-Therm. The newer one was lighter and lower to the roof. I did not add any new supports. The old one had some kind of al sheet that went over the exterior of the opening. I removed that too! (BTW I have saved all the old pieces. I always do that just in case)
The new unit is a piston compressor vs a rotory. It has drain holes on both street and curb side in the front. I have not connected the drain holes as I do not know where to do the connection. So the condensate just drains over the top and down the side. I know this is rather crude to have water draining down the side, however waiting to resolve the issue was not an option at the time of installation.
The new/used unit was obtained at AZ RV Salvage at the cost of $350.00. It came with installation instructions and a new mounting gasket. Installation was a breeze.
Pics are on my site.
>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Non Traditional AC - Not on the roof Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 63 03-12-2006 03:38 PM
Installing roof AC. Need a sealant nds Clearcoat, Exterior Paint & Trim 8 07-22-2003 07:33 PM
2004 30' Classic roof rack gklott Our Community 0 07-15-2003 04:00 PM
Roof Air Problams 1985air345 Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 07:40 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 12:01 PM
test
