02-04-2013, 09:55 PM
1954 22' Safari
Little Compton
, Rhode Island
roof AC unit in 54 Safari
Has anyone had experience installing a roof AC unit in one of the roof vents on an early Airsatream? I would like to installl one in my 54 Safari and am hoping the roof can support it. Also, any recommendations (brand and where to purchase)?
Thanks much!
02-04-2013, 10:28 PM
1979 23' Safari
1954 29' Liner
Orange
Not without some reinforcement. I put a new bow front and rear of the center vent opening and reinforced all the way around the hole. But then I had the inside skin out to make this easier.
Bill
Thanks much!
Just my personal opinion
https://billbethsblog.blogspot.com/
02-05-2013, 05:16 AM
1954 22' Safari
Little Compton
, Rhode Island
Thank you, Bill.
I plan on taking down the inner skin to fix some leak issues and replace insulation, too.
Did you use straight steel rod as reinforcement, running it from stringer to stringer?
02-05-2013, 07:19 AM
1979 23' Safari
1954 29' Liner
Orange
I had the reinforcement done by MEL Trailers in Orange, before Uwe started Area 63, and as I recall they used aluminum to make new bows and reinforcement channels and then wood spacers.
Bill
Thank you, Bill.
02-05-2013, 01:00 PM
1955 Safari
1955 22' Safari
Enterprise
, Alabama
Bill, about what was the cost of the bow work? I think I need to replace a couple
02-05-2013, 01:50 PM
1979 23' Safari
1954 29' Liner
Orange
I don't recall, but it was not much. You can make your own, take a piece of aluminum sheet, not tempered, bend into a c channel and they notch every few inches to be able to bend it to the shell contour. You can use two c channels and offset the notches to reinforce.
Bill
