Old 11-21-2008, 09:57 AM   #1
1976 31' Sovereign
Blairsville , Georgia
Return Air?
Hi all, The furnace in my '76 Sovereign is working well now but I have a question. Does it recirculate the interior air (like my house) by way of a return air duct or opening or does it continually pull in outside air or what?
Chip Arnold is offline   Reply With Quote
Old 11-21-2008, 10:01 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The heated air is completely separate from the burner air in the furnace. Air for the combustion section is pulled from the outside and then vented outside as well. The interior air is reheated and recirculated inside the trailer.
Richard
Old 11-21-2008, 11:17 AM   #3
1976 31' Sovereign
I have the under sink cabinet pretty much apart due to removing the tambour which wasn't sliding all the way open. Looking around under there, The outgoing ductwork is easy to see and understand but I don't see how the interior air gets back into the unit to be reheated and recirculated. It works fine but I'm curious and want to know how stuff works :-)
Old 11-21-2008, 11:25 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The return air is pulled up into the furnace, run through the heat exchanger, and blown back out through the ductwork. The return is usually an open spot on the furnace housing near the floor.
Old 11-21-2008, 11:28 AM   #5
rogerdodger's Avatar
Fresno/Clovis , California
On my trailer, the air duct is to the left of the heater. The heater is under the stove. I can see the intake duct from inside the front door entry. It is the only vent not throwing hot air, so I guess it is the intake??
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 11-21-2008, 11:29 AM   #6
1976 31' Sovereign
Thanks all. I'll have a better look at the thing when I go back out there in a while.
Old 11-21-2008, 03:20 PM   #7
1976 31' Sovereign
Well I ended up tearing out the whole front of the cabinets because I decided since the tambour was sticking I'll build a regular cabinet front with nice wood doors. Anyway, when I took out the under sink shelf and the furnace was completely exposed, I could see the return(s) easily. There are two openings in the furnace box approx. 2" X 10". One on the top and one on the side facing the under sink area. The one on the top was completely blocked by the shelf which was laying flat on top of the furnace box and completely covering that return opening. Running the furnace with both openings now free the unit puts out a lot more air at the heat ducts and the exhaust is much cooler! So I'm happy that I pulled everything apart! Now to build new facias and doors.
Old 11-21-2008, 03:36 PM   #8
1975 29' Ambassador
Reno , Nevada
The return air is not ducted but is expected to find its way through the cabinetry to the back of the furnace. That is where the blower is and you'll note the ventilation holes near the rear of the furnace to accept the air that is blown out through the ducts.
I don't know what it is about restricting air flow through the furnace but I have even encountered some whose ductwork didn't provide for sufficient flow to keep the overheat switch quiet. Keeping the area around the furnace clear is one way to make sure that the return air part of the loop isn't hindered too much.
I shall return!...........hopefully Van Our Community 7 09-08-2008 02:22 PM
4CU 004 : Dead Horse 2 -The Return of the Peeps! azflycaster WBCCI Rallies & Events 234 02-24-2008 04:55 PM
Past the Point of No Return kayelm Cleaning, Stripping & Polishing 3 08-13-2007 07:13 PM
Flamingo Return rickandsandi Off Topic Forum 5 08-03-2007 08:50 PM
The return of the Argosy..... Silvertwinkie Vintage Kin 25 04-06-2007 04:20 PM
