Old 12-23-2012, 09:43 PM   #15
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
drboyd
Thanks for the thread about furnace replacement.
I have not replaced mine yet, it seems to work fine, but I plan on replacing it before next fall for the following reasons:
1. Heat exchanger is SS versus cast iron, so it won't rust (thanks for the info idroba).
2. New furnace is more efficient.
3. No concerns about a hole in the cast iron heat exchanger (safety).
4. Spark ignition.
5. fan uses much less power to operate. I believe the new fans use only about 1/2 the power of the old fans, thus much less drain on the batteries when boondocking.
6. New furnace is probably lighter (like everything else).
Dan
Old 12-24-2012, 05:12 AM   #16
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Can we add broke and old to the club membership?
Is there a lower age limit on the club?
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 12-24-2012, 04:46 PM   #17
I guess I need to know how you tell the difference between lazy.... and tired?
Old 12-24-2012, 04:51 PM   #18
rogerdodger's Avatar
Fresno/Clovis , California
Depends on how broke you are!
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 12-24-2012, 04:52 PM   #19
If your getup and go just gotup and went, thats tired! LOL
Roger
Air# 29488
Old 12-24-2012, 06:51 PM   #20
1981 31' Excella II
New Market , Alabama
Is the heat exchanger stainless or just the burner?
Perry
Originally Posted by TouringDan View Post
drboyd
4. Spark ignition.
Dan
